Mud flaps - RokBolz vs. Others?
HorizonHunter
Joseph
Chapel Hill, NC
Grand Cherokee Trailhawk
Thanks so much for posting! That’s exactly what my build will sit like. I will be copying the flaps and steps.
I suggest getting some of your own hardware for mounting the flaps. There's 2 M6 that are 16mm when 20mm works better, and getting 2 longer expansion screws to replace OEM ones in the wheel well liners. Otherwise, perfect.
Sthomasson72
Chesapeake, VA
The Rokblokz work great, I remove them when going off road and put them back on while airing up. Very easy! Put them on the night I received my Bronco and not one rock scratch/ding yet!
Did you only install the front?
JimmyG
Greg
Ann Arbor, Michigan
Fords and Cadillacs
thise are zroads, but I’m probabaly gonna go with the IAG
Did you pull the trigger on the IAG's? I was looking at them too. Not bad 80 bones for fronts only.
jehines3
Easton, MD
Lexus RX350L, Chevrolet Silverado, Lincoln MKC
I didn't after watching the video, I see they went onto a Bronco that had SAS flares. As a standard flare build, I don't want flaps that stick out past the side.
JimmyG
Greg
Ann Arbor, Michigan
Fords and Cadillacs
Excellent, thanks for the input. Having a SAS build I may go with this as they should fit "just right" although the Mabett ones are even cheaper and look good as well. Decisions decisions!
