Broaddict Mud Flaps
mflynn227
Matthew
Greenville, WI
2024 Bronco
I HAVE to share! So I installed my Broaddict mud flaps a few months ago. Now, they look awesome...but that's not the best part. I had a bit of an issue with one of them and wrote to Amber, a customer service rep with Broaddict. She sent me a new one immediately! So now they look awesome and you know that you can always reach out to the company and they'll stand behind their product. They are AWESOME!!
https://www.broaddict.com/products/2dr-4dr-mud-flaps-splash-guards
Ford Bronco Broaddict Mud Flaps 72B56675-8742-45A8-B6F5-3AD09AE11EB5_1_201_a
Ford Bronco Broaddict Mud Flaps B3E8FFFE-00E0-4F28-9035-85156ACB1CCC
Sir915
Shawn
El paso
2023 Bronco
I had a set for 30k miles and zero issues and they do work very well.
mflynn227
mflynn227
Matthew
Greenville, WI
2024 Bronco
These look like a great alternative to the Rokbloks for the price. Is the metal part with the design on it removable?
I cannot tell you as there'd be no reason to take it off. It's the best part of the flaps.
mflynn227
mflynn227
Matthew
Greenville, WI
2024 Bronco
I think they are tacky and draw attention to themselves. It kind of looks like there's screws that could be removed. Are you able to confirm that?
[/QU
HA! Well, I believe blue Broncos are for suckers.
Figmo
Figmo
Frenchtown, MT USA
Suzuki Samurai, Bronco 2Dr WT, Gladiator Rubicon
Regardless of your color bias - the question is valid and remains unanswered: can you run them in either "half mode" or full on tacky mode by using those (what appear to be) screws across the middle?
On the street, the man demands tacky. On the trail - I can be me and free. So flaps that convert might be something some folks would like.
mflynn227
mflynn227
Matthew
Greenville, WI
2024 Bronco
I recognize the question is valid, but labeling something I am clearly excited about as "tacky" leaves one wondering why one would be so rude. Rudeness does not demand a response.
mflynn227
mflynn227
Matthew
Greenville, WI
2024 Bronco
Well, you ignored my question the first time. I'm assuming you don't have access to actually check, maybe those pics aren't even yours. This is clearly an add, and not a very good one.
Dear Lord, you’re a considerable jag! #1 I shared because Broaddict was awesome and I loved everything about the mud flaps. #2 Recognize how uncouth you are by disparaging that which I came to brag about. Don’t like something about them, just say “That part of the flaps doesn’t do it for me.” #3 You can now apologize for your wrongful accusation.
mflynn227
mflynn227
Matthew
Greenville, WI
2024 Bronco
You've actually talked me out of buying your product. Thanks anyway.
Ha! You couldn’t handle them anyway. You should go get a Wrangler anyway.
mflynn227
mflynn227
Matthew
Greenville, WI
2024 Bronco
I believe tire shine is for suckers...
That's awesome! I cannot lie: I've thought the same thing. But I can't help it! Hahaha...you're not wrong. But what do you do when you're attempting to blacken everything and your tires get that faded, brownish look?
NC_Oak
2024 4 door 2.3 sasq
My wheels and tires are never clean enough. on the wifes cherokee which I keep clean I use majic tire paint
mflynn227
mflynn227
Matthew
Greenville, WI
2024 Bronco
And my ride's a company car. There will be no off-roading for me.
SledDog30
Bob
colorado
Well…. Got mine on Thursday. Went to install them today. Started with drivers side. Looks like quick install. I pull the OEM fasteners in each wheel well and took out the one bolt for crash bars (I have a Wildtrak) and got ready to start.
But wait!!! I stared assembling and found I’m missing 18 screws and 17 washer for the front!!!!
I figure no sweat. I’ll take the screw and washers from the back set and finish the front.
NOPE. The rear set was missing all the washers and half the screws!!!
Since these momos don’t have a CS phone number, I ended up sending 3 emails. I will never purchase anything else from a company that does not have a CS number
I have no tolerance for stuff like this. None.
I could not even do a work around by using the rear hardware. BS!!!!
I have requested an overnight shipment of replacement hardware. So let’s see just how good their customer service is.
While they may look good, and they do, sitting on my work bench partially assembled. I’m sure as hell not going to put the OEM fasteners in just to pull them out again.
They just may end up in the for sale section.
mflynn227
mflynn227
Matthew
Greenville, WI
2024 Bronco
That's HORRIBLE!!! I cannot believe that! Sorry, man! I emailed and got a new replacement for one of mine (they sent a whole new set), no questions asked.
SledDog30
Bob
colorado
I’ll update this with my response from them. It sucks that their Chinese QA can’t get it right.
And actually If I knew that’s where they were produced and that they did not have a CS number I would have passed on this purchase
I should have found another manufacture and researched a bit more.
I still may do that and put these up for sale I usually purchase OEM flaps, but the don’t have the coverage I want. Gatorbacks are just too expensive. So I’ll look some more.
The 4 bolts/nut to remove the lower section is easy. If I keep them the lower metal will get painted black. Everything else is black on my Azure Gray Wildtrak.
