Mud Flaps -- install all 4 or just the fronts?
Deleted member 32220
Guest
I hope you like the RokBlokz! I just installed mine this past weekend...we'll see how they hold up. I initially installed all four flaps to the letter of the instructions, but the next day, I decided to experiment with the front ones, swapping the brackets from side to side. Doing this actually seemed to improve the stability of the flaps for me, as well as reducing the "buzz factor" where the upper edge of the flap rests against the fender flare. Plus, this swap repositioned the front flaps more perpendicular or "square" to the body surface of the vehicle than they were initially. I have the smaller tires of the standard Badlands, and even with the brackets reversed the whole flap assembly is at least flush with the crash bars, so I have no interference issues.
I completely understand your thinking on this. Turning mine around. They are on an angle trying to be flush w/ the flare. Yours are square w/ the body and it’s such a thin flap it looks fine with the small gap. They should re-write the instructions!
JT58Bronc
JT
Fl
I plan on going with just the fronts- going with Mabbet.
sgraing1
451xx
2022 Bronco Black Diamond.A Bunch More Junk.
Fronts only. Going to add rears.Not in a hurry for them.
Ford Bronco Mud Flaps -- install all 4 or just the fronts? 1660131398867
Razorbak86
Northwest Arkansas
Ford Bronco, BMW R1150 GS
Okay I’ve decided to get mud flaps to help with paint protection and friggin dirt splatter. Anyone go with just front flaps? I’ve got a Non Sqch Badlands. Gonna go with rokblokz Just wanna see pics or advice on all 4 or just front.
That depends… are you a giver (front & rear flaps), a taker (front flaps only), or an anarchist (no flaps)? ;) Some people just wanna watch the world burn. 😄
Bocapilot
Bocapilot
Don
Is the closeup pic after the bracket switch? Looks good 👍
BroncoPls!
Austin,TX
23 Rivian R1S, 22 Bronco
Ford Bronco Mud Flaps -- install all 4 or just the fronts? IMG_2838
Front only, rokblox
KIILew
Prosser, WA
2016 Silverado 2500 Duramax, 2020 F-150 3.5
Indeed it is a closeup of the "after bracket switch". And here is an image of the same flap before...
Ford Bronco Mud Flaps -- install all 4 or just the fronts? 20220806_132256
At first glance, there appears to be little difference. However, RokBlokz instructs you to place the whole assembly against the fender liner. In my case, this made the flap(s) rest in a somewhat twisted position so that the inner flap surface was not parallel to the tires tread surface, or - for that matter - the crash bar. The brackets have slotted holes allowing some fore and after adjustment with regard to the crash bar mounting bolts, but I decided to just swap and reverse the orientation of the brackets, then move them rearward to the degree allowed by the slotted holes and flush with the leading edge of the crash bar. So now, after swapping things, the mud flaps are essentially parallel with both the tire tread surface and also the crash bars.
The main advantage for me, beyond the slight cosmetic advantage, was affecting the area where the flap contacts the fender flare so as to reduce vibration potential.
Here are before and after views of the bracket placement. In the top (before) image, the flap contacts both the inner and outer edges of the flare, which lead to a vibration issue. Reversing the orientation of the brackets rotated the flap just enough to avoid contact with the inner edge of the flare.
Ford Bronco Mud Flaps -- install all 4 or just the fronts? 20220806_131958
Ford Bronco Mud Flaps -- install all 4 or just the fronts? 20220807_130454
Ford Bronco Mud Flaps -- install all 4 or just the fronts? 20220807_130521
Bocapilot
Bocapilot
Don
Thanks buddy. Much appreciate it. Now I’ll know what to do when they arrive
KIILew
Prosser, WA
You're quite welcome. This adaptation might not be beneficial to others, but with my particular vehicle and situation, it seems to work.
OJS NV
Tim
2015 Mustang 50 Year Limited Anniversary Edition
Made my own mounts that fit in the front rail, paid $15 bucks for the flaps from auto parts store and used some old scrap metal I had laying around. Run fronts only and they work great, been hammering them on rocky desert trails in AZ for months. No dents or scratches from debris kicking up.
Ford Bronco Mud Flaps -- install all 4 or just the fronts? 20220508_095022
Ford Bronco Mud Flaps -- install all 4 or just the fronts? 20220517_185621
Boreal
Colby
MB
www.cspencephoto.com
2022 Badlands 2DR
Rekgen Trophy Flaps, Front Only! I was hoping to reduce the door dingers on gravel roads and it did exactly that! About 98% less rock impacts ~ give or take. Still some mud up wash, but It’s meant to get dirty
Ford Bronco Mud Flaps -- install all 4 or just the fronts? FF5B237B-62AA-4370-8DF6-7BB3AD43CBA0
Ford Bronco Mud Flaps -- install all 4 or just the fronts? BA363EF2-31D5-48B8-89C8-54A9C676B161
Ford Bronco Mud Flaps -- install all 4 or just the fronts? DF59DFBD-A874-42EE-8D44-E324024B9FA6
RideEmCowboy
Portola Valley, CA
'95 Mustang,'08 Honda Civic,'03 15hh QH Paint mare
I need fronts and backs for the highly trafficked, deeply rutted & muddy ranch I work and board at. Fronts for my doors, rears to be a good citizen for cars following close behind.
I was able to use the $50 Ford OEMs on the rears, but Ford had to bail on the fronts: I have three constraints that make it hard to find fronts:
  • OEM sidesteps (not rock rails)
  • nonSAS (so crash bar is in place)
  • not handy w/ tools and don't own any body-shop type equipment--we have a great body shop, will let them do it
After hours of research on B6G, the wider web, and vendor sites (and thanks to all of you who responded to my DMs), I'm going with the Rokblokz fronts. Pricey, but peace-giving of mind, and it's my birthday this month.
Ali from @rokblokz customer service was great, and significantly influenced my decision to go w/ RB.
I'm attaching my table with photos and links to vendors, forum posts, and other reference sites. (Note: the numbering in the table got munged up going from Word, which doesn't recreated links in Adobe, to Pages-->pdf w/ links)
Bocapilot
Bocapilot
Don
Ford Bronco Mud Flaps -- install all 4 or just the fronts? 5471ECDF-D16E-4D47-8426-C9EF80493862
Ford Bronco Mud Flaps -- install all 4 or just the fronts? B448EFB0-AF8C-4F58-9402-15F710BE53FE
all four installed. Happy with results. Daily driver
Stampede.Offroad
SD
junk
... Plus, as badly as we are all concerned about windshield chips from rocks, I want to pay it forward.
Kind of disturbing how many are just installing the front for their own protection and basically telling everyone else to go **** themselves by not installing the rears.
