Mud flaps for Wildtrak with factory tube steps?
WildTrakFl
Southwest Florida
Picking up a 2024 4 door Wildtrak with factory tube steps and have been exploring the various posts on mud flaps. Was leaning towards Rockbloxz but thier website has this warning. “We have found that models with factory tube steps and larger tires may not have enough clearance between the flap and tire and will therefore experience rubbing.” I am trying to figure out that will apply to the stock tires and tube steps on the Wildtrak. I did fill out the contact form for Rockblockz and asked but but the response said “The factory tube steps may or may not cause rubbing with the flaps.” So, I’m still wondering.
I searched and found several older posts asking similar questions, but did not see any clear answers. Advice or recommendations for mud flaps that would work would be greatly appreciated.
Fordified1
Bob
Mid South Texas
What size tires do you have?
I had to trim the inner flange on my Mabett front mudflaps for 35” tire clearance because of the factory rock rails. I really like the Mabett flaps though.
Fordified1
Bob
Mid South Texas
The Wildtrak will have 35” tires.
Part of my clearance issue is the aftermarket +12mm wheel offset. Stock offset you probably will clear the Mabett’s without trimming. You definitely want mudflaps as soon as you can get them on there though. To protect your paint.
Bschurr
NY
WeatherTech
Ford Bronco Mud flaps for Wildtrak with factory tube steps? IMG_6365
Skott
Missouri
2022 Bronco
I've got factory tube steps on my WT, and I have the Mabett set on mine. They definitely help against rock slinging, along with the OEM trail armor rocker panels.
Fairly easy to install. I'll share photos, if I find them.
Red Sox 4Life
Yucaipa, CA
Corvette, Lexus GS350, Highlander
Rokblokz worked fine on mine with the factory tube steps (before I swapped them out for sliders).
Ford Bronco Mud flaps for Wildtrak with factory tube steps? tempImageVuALfZ
This is exactly what mine looks like, zero issues with RoKBlokz
DriveAllNight
Dan
N.J.
One Very Cool Ride
I bought the IAG IAG-I-Line right away because I was worried about all the rock throwing everyone said would happen and I didn't want rock chips. They aren't exactly what I wanted, but I haven't found exactly what I wanted so I bought them but haven't put them on yet.
Here's the interesting part, my Bronco came with the factory steps (which I didn't want) and they do a great job as rock blockers, so I haven't 'had' to put them on to save my paint. Sometimes you get lucky.
Mudflaps are a necessary eye sore - I don't like them, but I don't like rooster tails or throwing stones at the car behind me, so I like them as small as possible but also want ones that easily come off. I haven't had the time to figure it all out yet but I'm working on it.
Fordmanbob
Bob
KS
2018 F150 4x4 supercrew, 2006 F350 4x4 superc.
I installed with no problems
retiredarmymp
Steven
Whitehouse, Texas
2021 Bronco Badlands Sasquatch
I have a 21 Badlands Sasquatch with 2 inch lift. The RokBlokz worked great with factory tube steps with no rubbing.
Ford Bronco Mud flaps for Wildtrak with factory tube steps? IMG_6153
G1D1UP
J.
Gilbert, AZ
2023 Ford Bronco
Installed the Mabett mudflaps first thing after taking delivery to aviod annoying rock throwing paint damage. I shaved them down a little bit with a dremel tool to reduce the wheel rub, but for the most part, I am happy with them.
Ford Bronco Mud flaps for Wildtrak with factory tube steps? 20230527_074205
Bschurr
NY
Did weathertech change their design? I thought they had a gap between top of flap and fender flair(woooo).
?? No clue @NatureMan
I have them on my Braptor too but it’s a totally different design based on the “Rubbermaid” flares
Ford Bronco Mud flaps for Wildtrak with factory tube steps? 8815F07E-BAA0-4AE4-AF33-33844AF6501E
