Mud flaps for 2-door Bronco recommendations?
MI_Chris
Bronco, Explorer, Edge
I just took ownership of a 2 door outer banks bronco. I am looking into putting mud flaps on the vehicle. Looking for brands , tips, or tricks that may help me. I have a stock running board, and will not be putting large off road tires on. Thanks in advance.
Bad-Daddy-Lands
Todd
‘23 Bronco, ‘21 F250, ‘96 911/993
So do a bunch of other folks, which is why there are a bunch of threads on this topic. Give it a quick search first and you’ll probably find the info.
Fly by Nite
Walt
Pa
HBTFD
Newnan GA
F350
Since you have a running board the Amazon/mabett/IAG versions will work well. If you take the running boards off you will need much larger flaps to keep the rocks off the rockers and doors.
GroovyGeek
Boyan
'23 Bronco BD
If you will do moderate offroading you will need to a) get rid of the running boards and b) get mudflaps that are somehow detachable when you go offroad. Otherwise you will shred the flaps the first time you come down from an obstacle. If you will not be doing offroading then anything will do - the cheaper the better. I like how the ones above look - no needless branding.
jdbabb4247
Wernersville, PA
2022 Ford Bronco OBX
I have IAG on my OBX, look great.
MI_Chris
MI_Chris
that brand is what I am leaning towards. Did you have to modify/move the running boards? It seems like they are a little to far forward.? Do you have any pictures ?
jdbabb4247
Wernersville, PA
No, they fit just fine with the running boards
