Chritaka
DFW, Texas
'23 WildTrak; '06 Whippl'd Mustang (sold4upgrades)
I wanted to share some info/pics of this dash mount, which I’m really happy with! I like the fact that you don’t have to drill the dash as it uses hooks into your vents to secure the backside. I have the AR S.L.A.P. so I had to drill a couple holes to retain the other 2 mounting points.
Ford Bronco Mountains2Metal Dash Accessory Mount (Large) Installed IMG_6151
I first removed the SLAP and attached it to the mount and aligned the edges. I used a tap to mark the holes and drilled them out, then smoothed the edges with a Dremel. Touched up the pint with some flat Rust
Ford Bronco Mountains2Metal Dash Accessory Mount (Large) Installed IMG_6154
Ford Bronco Mountains2Metal Dash Accessory Mount (Large) Installed IMG_6155
Ford Bronco Mountains2Metal Dash Accessory Mount (Large) Installed IMG_6156
It comes with several adhesive pads to keep from marring the dash. I also attached some in the front, just in front of the main screw hole (where my thumb is) as once you tighten it down, it dips a little. This helped to straighten out and keep the edge level once snugged up, as well as protect the front edge from marring.
Ford Bronco Mountains2Metal Dash Accessory Mount (Large) Installed IMG_6157
Chritaka
Chritaka
DFW, Texas
Ford Bronco Mountains2Metal Dash Accessory Mount (Large) Installed IMG_6158
I I used BulletPoint arm (standard size) along with their 20mm balls and wireless charging cradle. The cradle is really nice, has some height adjustment on the bottom support and once you place your phone in the cradle, it senses and automatically snugs the sides.
Ford Bronco Mountains2Metal Dash Accessory Mount (Large) Installed IMG_6209
Ford Bronco Mountains2Metal Dash Accessory Mount (Large) Installed IMG_6208
ATLBronco75
Tom
Atlanta GA
2.7 Badlands
Is the ball mount on the back of the bullet point charger solidly attached or has the ball to ball adapter?
SubmarineNuke
Richard
Houston, TX
twitch.tv
Bronco Wildtrak
That looks really good, and I'm assuming doesn't interfere with the speaker. This looks like something I should add to my wish list.
buzpro
Binky
Tacoma
In the balmy Phoenix summer, that thing is gonna be a ball of heat on the dash!
Chritaka
Chritaka
DFW, Texas
Attached, no adapter req’d.
Ford Bronco Mountains2Metal Dash Accessory Mount (Large) Installed IMG_6216
Chritaka
Chritaka
DFW, Texas
It does go over the center channel, but doesn’t seem to impact much, if at all, given the slots.
Chritaka
Chritaka
DFW, Texas
I’m in Tx, so yeah I get you, but I don’t expect to be groping it! :ROFLMAO: Might work to grill a steak in a pinch?!
Seriously though, it works great with the Bulletpoint accessories and I haven’t needed to mess with any of it once I got it all set like I wanted. My phone stays super steady also and I have no trouble reading it a glance.
Arokcrwlr
Kraig
US - Alabama
Nice, I like that - saw it at Super Cel East. Would have been my choice, but I already have the Bulletpoint RubiGrid system which is another solid option, but does require screws into the dash. I can't forsee ever removing it, but if I ever did I would just get the anti-slip dash pads which would cover the screw holes.
MyBHinds
Kansas
1976 Bronco
Do you happen to recall what length of mounting arm you chose?
Chritaka
Chritaka
DFW, Texas
It was the standard 5.9”. I also got the long just in case, but the standard worked perfect for this spot.
Ford Bronco Mountains2Metal Dash Accessory Mount (Large) Installed IMG_6217
ThatWilsonGuy
23' Raptor | 23' BL SAS | Sport FE (sold)
I didn't realize there was another option similar to the bulletpoint.
One mod I did that you might be able to do was run the USB cable through the mount arm to clean it up a little.
Ford Bronco Mountains2Metal Dash Accessory Mount (Large) Installed 20230604_141956
Ford Bronco Mountains2Metal Dash Accessory Mount (Large) Installed 20230604_140635
Ford Bronco Mountains2Metal Dash Accessory Mount (Large) Installed 20230604_140739
Chritaka
Chritaka
DFW, Texas
Nice! I’ll have to check on doing that mod. Thanks for the tip!
