Morimoto 4Banger NCS Fogs: Impressive
Bronco365
Everglades
Markus
Ontario
2022 Ford Bronco Everglades: Eruption Green
Everglades
Installed the Morimoto fogs over the holidays.
I went with 4 Amber and 2 white beams. All in the wide beam pattern.
I decided to get the NCS models as the HXB I don’t think are street legal. I’m very impressed with the NCS line. Super bright and wide beam pattern.
I could easily drive with headlights off with these. I tested it. They have plenty of distance and I haven’t had one driver flash me yet so I guess they are aimed right.
It’s amazing how the amber helps with nighttime driving. I can see much better especially on poorly lit rural roads.
I bought the plug and play harness from Morimoto with the lights and brackets. Easy install. Harness is great quality.
Here’s a couple of pics. Highly recommend them. They are very high quality. Fit great. They Fill in the front bumper nicely.
Ford Bronco Morimoto 4Banger NCS Fogs: Impressive 41CA5224-336F-40D0-90D7-839375416654
Ford Bronco Morimoto 4Banger NCS Fogs: Impressive AC9F673E-09EE-4C6E-A282-DBD5A4E5D635
2020FordRaptor
Ty
Nevada
2020 Ford Raptor
Very nice.
Bronco365
Bronco365
Everglades
Markus
Ontario
Everglades
Thanks!
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Did you order that from us? The Morimoto kits don't include a "plug and play" harness. But the kits WE SELL do include our plug and play harness. The ones sold by Morimoto include a harness that has to get modified a bit, as it's a switch style harness.
NCS and HXB both have an SAE option for wide (fog)
Bronco365
Bronco365
Everglades
Markus
Ontario
Everglades
I ordered direct from Morimoto. Not sure what you mean about Morimoto harness modifications. I had to make no modifications. Maybe they updated their kit.
Good to know HXB is SAE
I picked NCS as I didn’t want to tick off other drivers with on road use. They are plenty bright.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Their kits come with a regular switch harness according to their site.
Bronco365
Bronco365
Everglades
Markus
Ontario
Everglades
Not sure what a “regular switch harness” is. The harness I received from Morimoto required me to mount the relay, connect a power and ground wire. Connect one wire to the aux switch wire of my choice and plug in the lights. Pretty straight forward. Thx
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Yeah it has a switch on it also, which is also why it has a relay. Our harness is just plug and play. Plug the lights in, connect the other end to 3 upfitters. Nice and easy. Morimotos makes you wire up a relay and then it has a switch on the harness also you need to opt out of using.
Also, does their harness have 3 switches to control the 3 pairs OR all 3 pairs are on at once (which would not make it legal for street use FYI, so make sure you only run 1 pair of lights on public roads)
Bronco365
Bronco365
Everglades
Markus
Ontario
Everglades
Thanks for the info. i was surprised that there was no way to separate the lights. Their harness is only able to turn them all on or off. Not separate. How much is your harness should I decide to separate them? Thanks again for the info. Much appreciated.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Yeah that's a standard harness. We include our harness at no charge.. so you get a better harness and spend less $$
NM_21Bronco
New Mexico
2019 Explorer
What did you go with as far as setup (Wide/combo/spot)? I'm going to get these sooner than later
Bronco365
Bronco365
Everglades
Markus
Ontario
Everglades
I went with all wide Beam Was considering a pair of combo beam amber with the wides but ended up with all wide.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
IDyeti
SPAM
Boise, Idaho
21 Bronco BD
Yeah your harness is the shit, stupid easy.​
I would recommending going with SAE white wide, SAE yellow wide, and white spot. I got yellow combo and kind of wish I got the sae wides in yellow. The spots are nice for distance throw as the wides do a great near/mid zone.
CliffordTheBigRedBronco
East Coast
The most popular setup we sell is
SAW White Wide
SAE Yellow Wide
White Combo
This way you have white and yellow fogs on different switches, then a combo for "everywhere else"
https://www.4x4truckleds.com/morimo...t-kit-for-2021-ford-bronco-hd-modular-bumper/
Our kit includes our own harness which puts each pair of lights on it's own switch for more control
Is the difference between the standard and HXB really worth the 200$ per light difference? Im going to order a set from you because i really like the idea of your harness.
