Installed - Morimoto 4Banger HXB A-pillar Lights
AK SNO RIDER
Ty
Alaska
Picked up a set of pods for the a pillars from @4x4TruckLEDs.com. Been wanting to try these new 4Bangers since seeing them at SEMA last year and I'm definitely impressed. Only 3 LEDs in each pod yet brighter than many 4 diode pods. These things pack a serious punch for their size, like a pocket-sized light bar. These are the COMBO beam.
A word of advice if anyone else gets these, grab a couple washers or replacement bolts for the mounts ahead of time. The slot in them is way bigger than the factory "Bronco bolts". I luckily had some black washers on hand, but I'll probably swap out for a longer bolt at some point.
Ford Bronco Installed - Morimoto 4Banger HXB A-pillar Lights 20220729_010325
Ford Bronco Installed - Morimoto 4Banger HXB A-pillar Lights 20220729_010320
Ford Bronco Installed - Morimoto 4Banger HXB A-pillar Lights 20220729_010342
And now for the good stuff...
Low beams only
Ford Bronco Installed - Morimoto 4Banger HXB A-pillar Lights 20220729_011221
Low+Highs
Ford Bronco Installed - Morimoto 4Banger HXB A-pillar Lights 20220729_011226
All 3. I have the pods aimed pretty straight ahead right now so there's a lot of overlap and they basically drown out the headlights.
Ford Bronco Installed - Morimoto 4Banger HXB A-pillar Lights 20220729_011232
Pods only!
Ford Bronco Installed - Morimoto 4Banger HXB A-pillar Lights 20220729_011240
Pods only without the light on the horizon... hard to get true darkness during summer in AK.
Ford Bronco Installed - Morimoto 4Banger HXB A-pillar Lights 20220729_011357
SZairborne
Shayne
Minnesota
2018 Dodge charger GT AWD
Did you use the aux switches or do you have a controller?
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Looks great!
Our kits include a plug and play harness that connects them to the factory OEM upfitter switches
Engineer Pass
Outback
Any discount codes for Bronco6G members? Thanks.
papakski
Wisconsin
2022 Ford Bronco Big Bend 4 Door
How was your experience with 4x4truckleds.com? I've read a lot of negative reviews on them. I am more than willing to try them as they have the lowest prices if someone says they're good
AK SNO RIDER
AK SNO RIDER
Ty
Alaska
How are these vs BD and DD?
I picked up a couple pair of DD SSC2 Pros for our new work trucks. The Diodes perform very well, but I think the Morimotos are brighter. I've never put my Bronco and one of the work trucks side by side to truly confirm though.
Friend of mine has Baja Designs on his truck. I don't know which exact models they are but I'm not impressed with their output.
My favorite are the Morimotos. Better looking, more compact and to my eye perform the best.
Video of the DDs from my work truck. I have them mounted on a headache rack
AK SNO RIDER
AK SNO RIDER
Ty
Alaska
I've since installed 3 more pair of 4Bangers on my Bronco. I love them. Headlights off in the video, showing each light individually, then combined.
White HXB Combos on the a-pillars
White NCS wides for street legal fogs
Yellow HXB wides
Yellow HXB combos
fallguy
Tennessee
2020 Defender, 2022 Outerbanks SAS, 1968 Mustang
Looks great!
This is what I used. Got mine from 4x4TruckLed. Shipping was very fast, great interaction. Would definitely buy from them again. Had to get the bracket elsewhere.
Ford Bronco Installed - Morimoto 4Banger HXB A-pillar Lights 20230217_145212
Ford Bronco Installed - Morimoto 4Banger HXB A-pillar Lights 20230220_091132
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Looks good. Although the brackets are not required to install the 4Bangers on a Bronco.
Allenm7
Allen
Los Angeles
Ford bronco
What brackets did you use?
AK SNO RIDER
AK SNO RIDER
Ty
Alaska
Look good. I’m going to try them out
I liked them enough I bought 6 more. Have since swapped bumpers and replaced one set with some 2Bangers and recently added a pair of BigBangers, and have a pair of 1Bangers on the rear bumper.
Ford Bronco Installed - Morimoto 4Banger HXB A-pillar Lights 20230820_173350
DallasCajun
Will
Dallas, TX
2023 Ford Bronco Raptor
Nice…good to see these installed and making the difference that the various online retailer videos show. Getting ready to pull the trigger on a set of HXBs from 4x4TruckLEDs…just can’t decide between white v amber as well as combo v wide.
I have a 30in Amber/Combo DD Light Bar on the way from 4x4TL so standard thinking would say get the Wide pattern but my use is typically more country roads/trails at higher speeds. Thinking about a Combo with the pods aimed somewhat outward to complement the High-Beam, OEM Raptor Fogs, Light Bar and Rigid Spots (not the oem fogs).
