Morimoto 1 Banger Cornering Lights installed
ThunderFlash
Doug
Washington
'24 4-dr WT, '22 2-dr WT, '15 Explorer Sport, '02 F250 SD V-10
Mounted a set of Morimoto 1 Banger combo beam lights on top of my crash bar mounts to serve as cornering lamps and wired into my fog light switch. With the extra clearance of a ADD Rockfighter bumper it projects light were I wanted it. The positioning is a bit vulnerable, but I'm hoping they can hold up to the abuse. I may 3D print a shield for them, though. The combo beam has a nice spread to it with a brighter area towards the middle. Very nice lights. The little dudes feel robust and the mounts are stout with a beefy, large torx headed carriage bolt for mounting. The T-20 Torx screws on the sides for the pivot point and angle adjustment seem to hold very well. Have some issues with the FORscan programing for cornering functionality, but I think I can get that resolved. Light pics are headlights only - 1Bangers only - both. I have the right one angled slightly more outward since right turns tend to be sharper.
Ford Bronco Morimoto 1 Banger Cornering Lights installed PXL_20260116_222240119
Ford Bronco Morimoto 1 Banger Cornering Lights installed PXL_20260118_043906103
Ford Bronco Morimoto 1 Banger Cornering Lights installed PXL_20260118_043948793
Ford Bronco Morimoto 1 Banger Cornering Lights installed PXL_20260118_043927772
MachingBird
Christopher
Western, NY
2015 F-150 Lariat
Nice! Got a link to where you got them?
Squirrel13
Brad
KY
Cool. I did the same thing with a pair of BD S1 with the trail lens. They are tucked back somewhat protected by the skid plate.
Ford Bronco Morimoto 1 Banger Cornering Lights installed IMG_3523
Ford Bronco Morimoto 1 Banger Cornering Lights installed IMG_3521
Ford Bronco Morimoto 1 Banger Cornering Lights installed IMG_3520
MachingBird
Christopher
Western, NY
2015 F-150 Lariat
You got a pic up those lit up at night?
Squirrel13
Brad
KY
Not now but I will snap one for you in the morning!
MachingBird
Christopher
Western, NY
2015 F-150 Lariat
Here are some quickies from a totally dark garage. This is only the pair of S1 nothing else
That’s impressive. I am really partial to the Baja designs. I have an S1 in my trailer receiver that is amazing, all by itself.
MachingBird
Christopher
Western, NY
2015 F-150 Lariat
Did you wire those to come on with your turn signal and enable them with forscan?
Squirrel13
Brad
KY
ThunderFlash
ThunderFlash
Doug
Washington
MachingBird, link is below
Tonight was the first long drive with them and they worked great. I used FORscan to make them work as cornering lights. The inside light comes on when the headlights are on and the wheel is turned. I also have the inside light coming on with the turn signal. They only illuminate at 25 mph or less. You can also just turn them on as fog lights. It's cool. I think I'll make changes to allow them on with high beams, too.
@Squirrel13, I like your set up as well. The skid plate makes a nice guard for them.
https://fueledutv.com/products/morimoto-1-banger-led-pods-hxb-combo-beam
dangerfoot
Justin
Austin TX
www.dangerfoot.com
White Wildtrak 4dr
Tonight was the first long drive with them and the worked great! I used FORscan to make them work as cornering lights. The inside light comes on when the headlights are on and the wheel is turned. I also have the inside light coming on with the turn signal. They only illuminate at 25 mph or less. You can also just turn them on as fog lights. It's cool. I think I'll make changes to allow them on with high beams, too.
Very cool. Would love a tutorial on the forscan side.
ThunderFlash
ThunderFlash
Doug
Washington
There is a pretty good tutorial stickied under the FORscan directory. That's what I followed after reading a lot of posts. It's pretty easy and straight forward, but if you have any questions, I'm NO EXPERT, but can try to help.
dangerfoot
Justin
Austin TX
www.dangerfoot.com
White Wildtrak 4dr
Thanks man. I'll wander over there, although my FORM projector really solved this problem for me.
