Modification for Oil Change Access
kodiakisland
Arkansas
5 minutes? I just dak dak the two back bolts off, and loosen the front two maybe 2 full rotations and boom that plate slides right off. Takes 30 seconds tops.
Yeah, but I got to get my old butt under there in the first place.
DUSTYcazOREGON
Craig
2022 Bronco Black Diamond & 2025 Yukon Denali. 2023 Mercedes Adventure Wagon.
Tactisquatch
Josh
VW Atlas
Have you actually changed the oil in this thing yet? With the stock plug (and warm oil) I can tell you from experience you’re not going to get a cute little run down into your drain pan directly underneath the plug. It’s going to end up all over the remaining slim section of skid plate and go everywhere as it comes out like a fire hydrant.. makes it dang near to the wheel.. It comes out so fast I had to modify my drain pan to fill faster. EDIT: added a more realistic photo for you
Stop it. That's just mean.
SPITmadFIRE
CA
Expert pro tip: you need a 27mm for the filter cap removal.
Nah the way mine was tightened from the factory you need a screwdriver to stab straight through it. But I’ve got a 2.3L with the cartridge filter so
BroncoWTFAN
NJ
MachE FE & BL SAS 22
Ah 2.3, yes different all together, however the OP has 2.7 so 27MM applies.
Sparkherd
Sparky
South Central Texas
www.sparkherd.com
Lifelong Ford guy.
I’m 72 Years old.
... and 30 seconds to get my body back into the standing position….
I'm 63, it takes me about 2 minutes to get back to standing.
I must be doing something wrong...
Ford Bronco Modification for Oil Change Access plan_to_get_back_u
dgorsett
colorado
F250, Mustang, Explorer
Just a note on the inverse: Why did Ford leave a giant hole under the front diff, the part most in need of protection?
