Mirror side lights
onebob
Scottsdale
2025 outer banks
Everyone knows the mirror side lights go off at 6 mph. Looking at a schematic I seems the easiest way
to make them stay on is to wire the buttons to the headlight hot under the dash. I don’t think it is necessary
to add a aux switch.
DarthLincoln
Chuck
Northern California - Contra Costa County
1999 BMW M coupe, 2023 Ford Bronco Badlands 2dr
How do you mean? Which schematic are you looking at?
The headlight/foglight/spotlight “switch” is actually just a controller that doesn’t directly send power to any exterior lights. It only connects to the BCM (via LIN bus) and Passenger Door Module.
If a button is pressed, those modules check the criteria for that request, and if criteria are met, like speed limit for the spots, the modules send power to the lights.
CalvinT
Calvin
Phoenix, AZ
This...
