Midland MXT115 Install
2020FordRaptor
Ty
Nevada
2020 Ford Raptor
Looks flush! Very nice.
luntz
Greg
Los Angeles
2006 Jeep Rubicon Unlimited LJ
Clean looking.
Did you install an external antenna? If so, where and how.
tobyw
tobyw
Toby
Washington
2022 4-Door
I did, although it's not what I had intended... Midland accidentally sent me the wrong cable and antenna mount to go with the 3db Ghost antenna that I ordered, so while I wait for the correct parts to arrive I temporarily installed the included mag-mount pencil antenna:
waveform55
Brad
TUCSON
2012 F-150
This is FANTASTIC. Couple of questions:
- How easy was it to take the panel off and then place it back?
- How are you powering the radio? Aux? Direct to the battery? Or just USB-C to the ports right behind the radio
tobyw
tobyw
Toby
Washington
2022 4-Door
Appreciate the feedback (y)
Panels were easy enough to take off, I just always cringe a little when yanking on plastic... Everything is held in with clips, with the exception of (2) screws on the top/outside edges of the center stack panel that are accessed by opening the glovebox on the passenger side, and dropping the panel below the steering column on the driver side.
I am powering and grounding the radio direct to the battery with 14ga wiring.
