MIC Hard top Function Question
Frappy608
NorCal
2022 Badlands Eruption Green
Hi, tried to search this up but couldn't find an answer -- I'm interested if on a 4 door bronco with the MIC, can you run with the front three panels in place, but the rear clamshell (over the cargo area) removed? My Badlands comes soon and I think with the washout interior this would be a great way to run -- easy to pop off the other three panels to go topless, but still provide some protection if it's cold / foggy / etc. Would be even cooler if Bestop were to make a Windjammer for the bronco as they do for the Wrangler. thanks in advance!
equitasforall
Out of the country until late 2025
2021 Bronco Badlands
I imagine you could do it once... for a very short distance. I would think afterward you would likely either feel like "mayhem" from the Allstate commercials or one of those "wanna get away" stories for Southwest Airlines.
Frappy608
NorCal
Ha! Thanks. It wasn't clear from the schematics as it looked like the front and mid panels all had dedicated attachment points, and that the middle piece simply rested on top of the gasket from the rear piece. I appreciate the info.
KABQ
Aaron
Albuquerque, NM
KABQ
Aaron
Albuquerque, NM
Ground_zero298
Scs michigan
Stable to 100mph+. No flex on the rear joints. My preferred setup. Don’t like the sun on my head.
stickshifthappy
RVA
Ford Ranger, 65 Mustang
AMTRV
Oliver
United States of America
22 Badlands 4dr, 22 6.7L Tremor, 1940 Ford Cpe
I run with the front 3 panels on my 4dr a lot……at hwy speeds. I like it and zero problems.
