MIC Hard Top Failed
Lej512
60th Anniversary
Larry
Queensbury, NY
2026 Bronco Outer Banks Sasquatch
60th Anniversary
Well, I had a good run. Today I discovered several cracks on the driver's side between the second and third window. I'm not overly concerned. Unless I pointed them out or you were looking for them, you probably wouldn't notice. I called the dealership and as I suspected I was told to get it in to the body shop, get a warranty claim started and they would replace it. Or, trade it for the 60th Anniversary edition in the show room. Unfortunately, the 60th Anniversary is all white and just doesn't grab me.
Bronco21Maybe
Justin
2015 F150, 202X Bronco, if it's ever built
I see the honeycombing in mine. Is that normal or a sign cracks will follow. And if it really is cardboard inside, and water gets in, that can't be good. No cracks so far. Maybe I should order some Flex Seal.
Ford Bronco MIC Hard Top Failed 1776900971710-30
KTP 30
Ray
Southern Indiana
21 Wildtrak 23 Bas Squatch 93 Mustang 87 mustang
Lej512
60th Anniversary
Larry
Queensbury, NY
60th Anniversary
Pic's ???
Stopped by the body shop today. Body shop manager took pictures and initiated the warranty claim for replacement. In and out in 15 minutes. I consider myself lucky to have this kind of relationship with my dealership.
Ford Bronco MIC Hard Top Failed IMG_0871
