Mic 2.0 different colors?
Roll Sound
Hollywood
2021 Wildtrack 2DR MIC OW, 2014 KTM RC8R
I have a 2 door MIC, and the driver panel is a little lighter than the passenger, which matches the clam top. So one out of three a little lighter, wonder if that panel was replaced on mine at DM? I'll report it to my dealer monday.
Tricky Dick
Dick
PNW
www.TD-Distributing.com
I wonder if they saved some of the old sections that’s why it’s lighter
I'm assuming so. They probably evaluate each panel and only replace the "bad" ones. That middle section was probably baking in the sun on DM all summer.
jaruss01
NJ
Mine is off too. Slightly. Not as disturbing as some of these photos.
Although mine is inverted. The mid panel is slightly darker than the front and clamshell. From other examples I’ve seen this is more common. But the two photos here are showing the mid panel being lighter. Needless to say it seems like the front panels and clamshell match and the mid panel is the outlier being either lighter or darker.
I checked the “when polymer was applied” sticker on the clamshell (rear passenger quarter) and it was inline with my build date. I know they darkened the top for 2.0 slightly or at least compared to the preprod. My mind was quick to think the front panels and clamshell would be 2.0 and darker since they needed to address the pop pops in the front panels and the open seams in the clamshell , but could get away with re-using the mid panel. so my immediate thought was that my mid section may be older/gen1 and lighter in color. But mine is the opposite. Although those that posted photos are more consistent with my thoughts - that the mid panel is lighter in color.
given basically all photos have the front and clamshell consistent the most likely thing is that the perfected the color for 2.0 so the front/clamshell is always consistent, but the 1.0 had inconsistent colors and they reused the 1.0 mid panels. In some instances it’s darker or lighter. But we probably all have similarly colored 2.0 front panels and clamshells
dgorsett
colorado
F250, Mustang, Explorer
Mine's the same, but opposite sides, i'll meet ya half way and swap ;) Really doesn't bother me, I only notice when looking from above.
WuNgUn
Ontario Canada
2 door Squatched
Well the middle section of my MIC 2.0 top is clearly lighter than the front and back. Anyone else notice this?
Must be a Dirt Mountain Bronco. I feel bad for the Bad Batch folk...
WuNgUn
Ontario Canada
2 door Squatched
They noticed just chose not to do anything which is bad they figured the dealer would paint it
Well, the factory can't paint it after the fact. Lol. Not unless you wanna strip it back down to the shell.
What'cha gonna do... Not accept your Bronco at delivery?
MDbeachguy
md
this thread is a dumpsterfire
sgraing1
451xx
2022 Bronco Black Diamond.A Bunch More Junk.
It's the new Tutone option.
Bronco21fan
Angelo
NewJersey
You
Never know what anyone will do when that situation comes up if there’s a ton of stuff wrong or if it’s totally destroyed like the one that came off the convoy I could see someone refusing delivery and just order another or move on to something else
lakesinai
Charleston SC
No, mine (DM Built Oct 7) are the same color. The middle panel seems to be the anomaly for you. What is your built date?
