Melted plastic smell
Trail_Runner
Me
MI
2021 F150, 97 Jeep TJ, 2022 Bronco
I have around 100 miles on my 2.7. There is the oder of burnt/melted plastic coming from around (I think) the engine and smells strongest around the passenger side.
I don’t see anything touching the turbo or exhaust on the side and no smoke or visual fumes.
any one have any ideas?
thanks.
rtazz17
Connecticut
2022 Ford bronco big bend
Sounds to me like typical brand new car smell. This happens to us with every new vehicle. Of course I dont smell what your smelling but sounds normal
Ground_zero298
Scs michigan
Mine does the same thing. I’ve looked 3-4 times for anything touching. Haven’t found the cause yet and nothing burnt up.
Trail_Runner
Me
MI
There is a lot of plastic under the hood.
I figured if wasn’t the only one it may just be off gasing of new plastic from the engine bay heat.
Losy
Long Beach, CA
Gen 1 Raptor, GL63, S7
i now have 500 miles and experienced the same burnt plastic smell as you when I hit 250 miles. i chalk it up to normal new car break in period.
XirallicBolts
Xira
Midwest, USA
2016 Flex EcoBoost, 2022 Silverado LT
Ditto, noticed it most at stoplights. It disappeared after a couple hundred miles
Lifeliberty
Moonbeam👀
Columbus, OH
I have never smelled burnt plastic in any new car, I've had 3 and this bronco
Off gassing is just new car smell, burning plastic is different
Is this the new normal?
Trail_Runner
Me
MI
I have a 2.7 in my f150 and didn’t smell anything, but It’s not a convertible.
As mentioned above, it is noticeable at stop lights
the 2.7 is crammed in a bit more tighter in the Bronco vs the F150
PrincipalD
Ryan
Sioux City, IA
Expedition, Bronco
I had an odd smell with my 2.3. It went away and I chalked it up to a new car. It was kind of a hot plastic smell. I had a lot more miles on mine than yours when it happened. I think it may have been one of the (first) hotter days I had it and may have been related to the AC. No issues before or after…
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
Same for me. I was concerned too, but after 1,000 km I think it stopped. Wasn't overly concerned about it.
Interior guy
Dan
2022 bronco
5,800 miles and I have a plastic burn smell coming mostly from drivers side especially after a drive for over 10 mins
chuthis
SoCal
22’ Bronco
I also have a similar smell and have noticed it from day 1 when we brought the vehicle home. Currently just over 600miles and still smell it. Chalking it up to new vehicle off gassing… I guess.
Evans67bro
Evan
Easton Maryland
2019 F250, 67Bronco,2022 BD,2023 BD
My badlands with the 2.7 had that smell until about 1000 miles then went away. My new 2.7 blackdiamond has the same smell only got 300 miles on it. Funny my wife's 2.3 didnt have the burnt plastic smell nearly as bad as the 2.7 and it went away after a couple hundred miles.
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Good morning! If you send over a private message with your VIN and dealership info, I can look into this for you.
JeebusCripes
Mn
‘94 M998, ‘89 Wrangler
I had this same thing and I posted the same question. If it persists past 500 miles I'd be surprised. Mine was the new car funkiness and now that the bronco is up to 1k miles the smell stopped. If my setting were max AC that's when I noticed it the most.
Someone recommended checking to make sure the wiring harness wasn't left unzipped and rubbing against a belt.
