Maxtrax mounting options with a soft top Bronco
Bird Dog Off Road
Jody
Phoenix, AZ
www.youtube.com
I've only seen one viable option so far with the American Adventure Lab, but it's a little bulky if all you're wanting to do is go off-roading with your traction boards.
Anyone have a different product or idea they are using or planning to use?
Stick355
2004 Mach 1, 2020 Explorer ST, 2021 Ranger Tremor
A friend of mine gave me his old rockslide Engineering EZ rack set up, as I didn't want to put mine on the roof, I'm getting a 2dr. I found a roof rack mount by Racksbrax on Amazon. I'm going to try and marry the 2 together so i can mount the boards vertically on the side of the spare.
Ford Bronco Maxtrax mounting options with a soft top Bronco Bronco-1
Ford Bronco Maxtrax mounting options with a soft top Bronco Bronco-2
These mounting plates are made for Maxtrax and pins that MaxTrax sells.
Petek70
Denver
68 bronco, 76 bronco, 18 raptor
ICUGAZN
Kevin
Woodbridge, Virginia
2019 Raptor
Petek70
Denver
I have the EZ Rack system now. I guess with this from BA Tents, you could have the boards oposite of 1 RotoPax. Or maybe have a rotopax on each side of the spare, and the Boards mount on top of the spare? All 3 could use the EZ Rack strap.
I haven't seen one in person or the EZ Rack but if you can slide either of them around the strap I wouldn't think it would be an issue to get them all on one strap.
ICUGAZN
Kevin
2019 Raptor
Here is my current setup with the EZ Rack.
Ford Bronco Maxtrax mounting options with a soft top Bronco 20211223_182329643_iOS
2Jeeps&PatriotX1
Denver, CO
My wife asked the same thing last weekend when we were out in the mountain snow and I realized that I left the matrix attached to the camper sitting in the garage. But hey, I at least had all the other recovery gear with me lol.
dcg2
Don
PA
Honda CR-V
Thanks for the visual.
This seems like a flexible, reasonably priced solution. Especially since it seems like it would be easy enough to mount it when going off-road and unmount it when not.
Would you feel comfortable positioning them vertically and mounting a hi-lift jack on one side and a set of max traxs on the other? As far as them sliding around?
MNBigfoot
MN
Adding a 30lb jack plus whatever the mount and the Trax weigh on top of the weight of the spare is asking a lot of those factory hinges, IMO.
ICUGAZN
Kevin
2019 Raptor
Yeah that would work. Trust me, they don't slide around at all.
dcg2
Don
PA
Honda CR-V
Hmmm.
2 x 2.5 Gal Rotopax with gasoline are 31 lbs = 1 Hi-Lift Jack
The mount weighs about 4 lbs?
Max Trax MK II are 17 lbs
And this would be mounted only when off-roading. I'm not an "overland" (or camping as old people like me call it) kind of guy so I don't think I'd be opening and closing the tailgate a ton while this was mounted.
But I think you make a fair point
JediMcMuffin
Tommy
2026 F-150 Tremor 401A
someone has to find out :) i am betting the max trax have issues clearing the center tail light. personally I'd be fine having maxtrax on one side and a single fuel can on the other.
Bird Dog Off Road
Bird Dog Off Road
Jody
Phoenix, AZ
www.youtube.com
Let us know how your project turns out!
JediMcMuffin
Tommy
so bad ass tents is literally 5 mintues from my in-laws place. im just gonna roll over there and see whats up about it sitting on top of the rear tire.
