Lumbar Support in MGV Manual Seats?
Tilzbow
NV
GM Sierra Diesel Pick Up
Can anyone who’s taken delivery or test drove a Bronco confirm if the 6-way manual marine grade vinyl seats in the Badlands and/or Black Diamond trims have adjustable manual lumbar support?
I assume this is a knob on the side of the seat back as with most manual seats that have manual lumbar adjustment.
Dads_bronze_bronco
08 JKUR / x_x 00 TJ x_x
My understanding is the driver side does and the passenger does not - but I have not physically verified this in person.
iamchewby
Chewby
Wouldn't surprise me, in my experience this is pretty standard across Fords with manual seats.
72F262
Doug
Charlotte
18 GT350, 72 Mach 1, 22 Bronco 2 Door
On the BD demo I looked at with MGV, driver yes, passenger no. You are correct, it is a round knob to adjust.
Tilzbow
NV
Excellent, thanks for confirming!
FunForAll
WA
Bronco, 2 F-150s, Explorer, Mustang
I drove a Badlands yesterday and can confirm driver's side lumbar adjustment in the manual MGV seats. Along with the telescopic and height adjustable steering wheel, I was pleasantly surprised at how configurable the cockpit is with the few adjustments. Very comfortable seats! However, kinda like memory foam mattresses, I did feel warmer than usual after about 30 minutes.
Has anybody compared the Big Bend to the Outer Banks cloth seats? Besides color and the ribbing, are there differences in quality feel or comfort?
mikonrad
Minnesota
2015 Ford Fiesta SFE, Toyota Rav4
So we have confirmation about the BD not having passenger lumbar support. I'm *assuming* the Badlands wouldn't be any different but does anyone with a badlands or been inside a Badlands have confirmation on passenger lumbar?
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
Bringing this back from the ☠ - but, the lack of lumbar for the passenger is starting to take its toll with my better half on longer drives. Has anyone figured out a solution? I’d like to continue to get some enthusiasm when I suggest a road trip/off-road adventure.
I installed Desert Does It jackers on my side and appreciate them - I’m gonna get a set for the passenger side. Might help a bit, but basically complaints about siding out of the seat and general discomfort.
I’ve seen those strap on mesh lumbar supports - but, wondering if there is anything more rugged or well known in the off-road community.
F OR D
BD Green Machine
Chinese fire drill at a red light...I do it and make the passenger drive ;)
Merc4x4
steve
I asked once about the Raptor MGV seats, if the passenger has lumbar adjustment, but didn't get an answer.
The rock starts programming the online build and price config don't care about accuracy, so no good relying on that.
Could buy a drivers seat and tear it apart to try to make your own passenger seat have adjustable lumbar.
Or if the power passenger seat has it, I bet it's not too hard to retrofit the power connection. You'd get the adjustable head rest too. Then re-skin with your MGV covering, or katzkin.
At least, that's what I've been thinking about to get adjustable lumbar and MGV.
redone17
Cold Spring, NY
Oh, MGV Raptor seats would be a nice upgrade!
I have to look into photos of what that looks like. Wonder if the tracks are the same.
Assuming the cloth seats don’t have lumbar?
Are all leather seats powered? I assume so as well.
Dads_bronze_bronco
The passenger side still does not have manual lumbar on Bronco Raptor MGV seats, so I bought this:
Ford Bronco Lumbar Support in MGV Manual Seats? Screenshot 2022-11-15 at 9.34.12 AM
Pulled the back off the passenger seat off and installed it.
Note: it's really easy, except the seat frame is razor sharp so wear gloves (two cuts and there's a few blood stains on that inflation bag 😅 ) and have a small piece of PVC pipe or flex loom to protect the inflator tube where it runs between the frame and the padding.
Maybe @flip can post it, but pages 3-7 in the Front Seat Lumbar Assembly G2235607 part of the service manual explain how to remove the seat back.
flip
Phil
IN
www.ruxerparts.com
Fords
Special Tool(s) / General Equipment
Interior Trim Remover
Removal
NOTE:
Driver seat shown, passenger seat similar.
  1. Remove the front seat.
    Refer to: Front Seat (501-10A Front Seats, Removal and Installation).
  1. If equipped, adjust the front seat manual lumbar to the fully relaxed position.
Ford Bronco Lumbar Support in MGV Manual Seats? video
Ford Bronco Lumbar Support in MGV Manual Seats? Hel
  1. Remove the front seat side shield screws.
  1. Remove the front seat manual height adjusting handle cover.
    1. Lift up on the front seat adjusting handle.
    1. Release the retainer and remove the front seat manual height adjusting cover.
    1. Remove the retainer and the front seat recline adjusting handle.
    1. If equipped with manual adjusting lumbar.
      Remove the retainer and the front seat lumbar adjusting handle.
  1. Remove the front seat side shield.
    1. Firmly grasp the front seat side shield, lift up and out separating the front seat side shield from the recliner bracket.
      Pull the front seat side shield over the front seat manual lumbar adjuster.
    1. Slide the front seat side shield forward.
  1. Detach the front seat electrical connector retainer and position the wiring harness aside.
  1. Detach the front seat backrest cover straps and position the front seat backrest cover aside.
Seats with soft back panel
    1. Lift the front seat backrest cover flap.
    1. Release the front seat backrest cover hook-and-loop strips.
  1. Unzip the front seat backrest cover.
    1. Lift the front seat backrest cover.
    1. Release the front seat backrest cover retainers.
Seats with hard back panel
  1. Detach the retainers and pull the front seat backrest panel away from the front seat backrest.
    1. Release the front seat backrest panel retainers.
      Use the General Equipment: Interior Trim Remover
    1. Pull the front seat backrest panel away from the front seat backrest.
  1. Remove the front seat backrest panel.
    • Pull the front seat backrest panel down and out.
  1. Position the front seat backrest panel anti-squeak flap aside.
All seats
    Position the front seat lumbar assembly cable away from the front seat track.
    1. Detach the front seat lumbar assembly cable retainer.
    1. Detach the front seat lumbar assembly cable from the front seat lumbar actuator.
    1. Release the front seat lumbar assembly cable from the front seat lumbar actuator.
  1. Remove the front seat lumbar assembly.
    1. Detach the upper J-hooks.
    1. Detach the middle J-hooks.
    1. Detach the lower J-hooks.
  1. If required.
    Remove the screws and front seat lumbar actuator.
Installation
  1. To install, reverse the removal procedure.
stickshifthappy
RVA
Ford Ranger, 65 Mustang
2 door Badlands owner here, yes the drivers side does, I haven't looked at the passenger side.
Karl_in_Chicago
Karl
Chicago
Well if Ford ever does end up building a RHD model maybe we'll have an option there . . .
Hmmmm, bet my money on Ford building my 7/20 reservation before or after they build a RHD model? I'd ask my Magic 8 Ball but it would probably just explode in protest.
Good info in this thread, very helpful. I honestly was unaware that the BL MGV didn't have lumbar in the passenger. I was more than OK with the tradeoff to get MGV and not have power but not having lumbar for my wife's bad back is not good so good to know what the options are. I see some of those sculpted cushions in the future.
