LP6 and mounting options for modular bumper
TEAMSLO
NV
youtube.com
23' Bronco 2.7 4d Oxford White (sold) & '23 Jeep 392
Have been putting this off for a bit. I have the Baja Designs LP6 for the modular bumper which I would like to keep at least for a bit. Problem is I ordered the spv kit which I could use, not sure if it rattles but sticks forward a bit too much for my liking:
Ford Bronco LP6 and mounting options for modular bumper 1702410030702
So then I ordered the mini bar with light mount which I do like the "look" but rattles so bad it's more like a strobe light, I'm surprised I haven't had a seizure from them:
Ford Bronco LP6 and mounting options for modular bumper 1702410097579
Anyone found a solution to mounting pod lights similar to the LP6 size/weight without rattles?
BroncoRunner23
2023 Bronco
Johnny Rebel
LA
2021 2D Big Bend, 2022 Bronco Raptor
I used the LP6 brackets that came with the lights. For this location, I had to cut the inner side of each bracket to follow the lower valence contour so they could be aimed correctly and not make contact with the paint. Had them installed for over a year with no issues.
Ford Bronco LP6 and mounting options for modular bumper Baja Designs lights 2
ironmike
2022 Bronco Raptor
Just drillin’ holes is my jam!
TEAMSLO
TEAMSLO
NV
youtube.com
cobralsc
TX
04 Mini / 01 Viper
Dang OP...you were going through the same thing as me at the same time. So I am a little late to the party. I also have the SPV brackets. I too did not like how far they stuck out. Also, I wanted to add quad set of LP4s instead on on set of PL6s. So here is what I did.
Ford Bronco LP6 and mounting options for modular bumper 20231220_150044
Ford Bronco LP6 and mounting options for modular bumper 20231228_135832
Ford Bronco LP6 and mounting options for modular bumper 20231220_174139
cobralsc
TX
04 Mini / 01 Viper
I'm still in the testing phase. I cut the excess from the SPV brackets and drilled holes so I could angle the bars to give me a staggered look to match the bumper. So far the brackets don't rattle nor bounce. Once I am convinced I have everything just right, I will take the brackets off and use them as templates to make new bars and the weld them to the SPV bracket, that way I end up with just the bolts for each LP4.
Ford Bronco LP6 and mounting options for modular bumper 20231224_160748
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
At that point you shoulda just went with our LP4 Linkable kit :)
https://www.4x4truckleds.com/lp4-li...4-pro-for-2021-ford-bronco-hd-modular-bumper/
Ford Bronco LP6 and mounting options for modular bumper 314588949_10222221473781202_2328309308712981032_n
spidydt
Diego
Long Beach
Subaru wrx STi
I have the "capable bumper"
You have no idea how simple your "problem" is
