Lower control arm skid plate
Mc1guil
Phoenix, AZ
2022 Subaru Outback Wilderness
Does anyone know of a skid plate for the co from arms that works with the Hoss 3.0. I purchased the Jks one but it doesn’t work, different bolts and spec versus the other variants
Any links?
35tires
'23 Bronco, '21 4Runner
You do not need one. That is an unnecessary product. Get engine skids, gas tank, etc but you do not need those I assure you. More weight and no benefit.
Ground_zero298
Scs michigan
You’re correct. You don’t need one, you need 2.
Pretty bold statement if you don’t know what terrain they’re running.
I run lot of big woods and fire trails. My dv8 a arm skids have ate a couple logs, stump heads and sticks. With the angle of them they have allowed the arms to pop over and help deflect down. They’re needed on mine. I can assure you of that.
fordbroncowildtrak2023
Phoenix, AZ
Silverado, Bronco
I did a test fitment of the RCI skids over the weekend on my HOSS 3.0 equipped Wildtrak. They will work just fine. I need to install my manual stabilizer bar disconnects (AC Fab Sasquatch Links) first because these skids cover the lower bolts.
toughtoaster
Kansas City
2012 Mustang GT, 2022 Bronco Badlands
Do yours happen to rub or contact at full lock? Mine might have in a parking lot today… need to investigate more
Phoenix, AZ
Silverado, Bronco
Any links?
Here are the RCI lower control arm skids on the driver's side. They fit without issues.
Ford Bronco Lower control arm skid plate IMG-3121
Ford Bronco Lower control arm skid plate IMG-3123
dusty1
Dustin
Ballwin
2023 Wildtrak, 2011 LX 570
What did you torque the bolts to? I've seen a several different torque specs for the bolts.
Phoenix, AZ
Silverado, Bronco
Mc1guil
Phoenix, AZ
Phoenix, AZ
Silverado, Bronco
gmac71
Glen
Vancouver
'20 Ford Expedition; '21 Ford Bronco Badlands 2dr
Mine rub at full lock on 33" tires with the +55 offset. The thud I kept hearing was when it hit the wheel weight.
Ford Bronco Lower control arm skid plate IMG_0578
