Lose auto up feature every time I use global open.
Brsox
Bill
Rhode Island
2023 4Runner TRD Pro
Every time I use global open to open all four windows with my key fob, I lose the auto up feature on my front passenger window. I can fix it with the reset procedure but it's a pain in the a** to have to do that every time I want to use global open. Opening and closing using auto up and down, normally, doesn't cause the issue. Anyone else notice this?
B-Dog15
Brandon
Covington, Ky
2025 Base 4-Door
Doesn’t happen to me every time but occasionally it will. Now that I think about it though it hasn’t happened in a while. Mine is usually the rear driver side window but I honestly can’t remember the last time it happened.
I do know the windows can get weird if they get dirt l, grime, etc on them or around them so maybe try and clean them and the channel off really good. That might help.
ssitruc
Oklahoma
'25 Bronco Badlands
Happened to me... once. The day after I did the mod I used Global Up, after that the auto-up on the passenger front door would roll up the window then go back down part way. I "retrained" that door's window and it hadn't done it since... hopefully I didn't just jinx myself.
Nibroc99
Corbin
Rochester, MA, USA
www.corbonthecob.com
2022 Wildtrak: The WildeBeast
This happens to me consistently every time I use global windows. My passenger rear window won't go all the way up without jumping back down like it hit resistance. I have to try to retrain it like 10 times to get it right. I even have the premium care warranty and Ford wanted to charge me $169 diagnostic fee to find the cause of the problem before they can tell me if the solution is covered under the extended warranty. Such a fuckin scam.
