Looking for stage 4 - 57 mm turbo
JerryG
Rich
NY
Ford Bronco
Does anyone have an extra stage 4 turbo that they would like to sell?
I currently have one and want to send the new one out for heat treating w/o losing my Bronco.
MWILD
Central North Carolina
2021 Base/2DR/2.3/MT & 2023 Model S Plaid
You’re better off buying a stock turbo on eBay and having CRP or TurboBay whip one up for your.
On a separate note, who tuned your Bronco?
23OBX2.7
AB Canada
2023 Bronco
...or the Garrett FP turbos or from recyclers
JerryG
Rich
NY
Ford Bronco
CR-P is shut down thru the summer as a result on tariffs coming from Canada- that's what has me reaching out.
MWILD
Then I would reach out to Matt at TurboBay. He’s currently building my turbo, which will have a similar sized compressor wheel, but with a larger turbine as well.
Dmorty217
Derek
Venice FL
Camery
What do people have to say about TurboBay, i live not that far from them but as i look at them on a map I am confused as to if they’re really where they claim to be? It appears to be the typical Florida strip mall with random businesses, not a place that rebuilds turbos.
MWILD
Nothing but good things to say about the owner, Matthew. He’s knows his stuff when it comes to turbos. The highest HP Ranger Raptor is using his modified Garrett’s.
https://www.fordmuscle.com/tech-sto...r-roars-on-the-dyno-with-700-plus-horsepower/
He’s also a one man shop, so turn around times can take longer than some larger shops.
He’s building the Turbo for my 2.3L, so I’ll have more to share when I get it.
23OBX2.7
AB Canada
2023 Bronco
They shut down for months instead of increasing peices or finding an alternate vendors....sounds like a convenient closing doors explaination.
JerryG
Rich
NY
Ford Bronco
Are you going with a 54mm or 57mm?
MWILD
Should be closer to 57mm. I’m also adding a T51R mod, so that could impact the size a little bit. I’m still waiting on the final spec.
