locking axles
bruce 1
bruce
pa.
2023 bronco OB 4door 2.7 velocity blue
i have ordered OBX it comes with an open rear axle when you put it in 2wheel drive which 2wheels are active. also when you put it in 4wheel drive does it activate all 4 wheels and if so why do you need locking front or rear axles if all 4 wheels are pulling.
EvlNvrDys
Hunterdon County, NJ
Or.... I can delete all that garbage and post this:
Ford Bronco locking axles 1616758218854
Ford Bronco locking axles 1616758311458
ilkhan
Stuart
IA
None
2wd will be the rear axle.
With open differentials when it's in 4wd both axles will get power. But in low traction situations, if a wheel spins that wheel will get all the power and the other won't be pushing at all. Locking differentials lock the wheels on that axle together, so if one spins the other will get power to pull you free.
Used2jeep
Massachuvian
2007 Crown Vic P71
If you haven't seen this video yet. It is an informative watch.. Start at 2:18. Also, it is widely speculated that the computer would activate some type of limited slip in addition to a physical limited slip. The GOAT modes should also assist in that aspect.
Valhalla
Valhalla
Chattanooga Tn
Is this a real post? are you completely new to the 4WD community? It feels like a troll. If not never post on pirate4x4.com!!!
Valhalla
Valhalla
Chattanooga Tn
Skinny pedal 2wd open is more 1 wheel than you!!!!
MNBigfoot
MN
Considering the post is from back in 2021, perhaps he's no longer new to the offroad community.
Valhalla
Valhalla
Chattanooga Tn
sorry, drinking, it showed up under new... rough day at the factorayyy...
GoHack
Palmdale, CA
'25 Bronco, 2.3L 4-Cylinder, 7 Spd. Manual, 4 Door
An Open Differential is just that, open, w/power going to but one wheel. If you've ever gotten stuck, like in snow, you will only see one wheel spinning.
A Locker Differential, when disabled, is Open, just like on an open differential.
When engaged via an electrical/pneumatic/or vacuum switch, it is Locked, w/both wheels Locked as in one solid axle. There is no disengagement when turning a corner, and as such can only be used Off-Road on a loose/slippery surface, such as on dirt and gravel, snow, ice, and rain (heavy).
Finally, there is a Limited-Slip Differential which is always engage, using a clutch, where one wheel is allowed to disengage when you make a turn. It can be used on all road conditions, including on gravel and dry pavement, though it not as strong as a Locker, especially w/big wheels/tires, and under extreme conditions such as heavy offroading.
Now there are an assortment of different differentials in between, w/Open Differentials using the brakes to apply pressure to the spinning wheel, in order to help transfer power to the non-spinning wheel. That's become pretty much the standard norm w/many vehicles now-a-days, w/an assortment of different names. I had a Toyota Tacoma TRD Sport which said that it had a Limited-Slip Rear End, when in fact it simply used the brakes to control the traction.
Then there are Lockers which are always engaged, which uses a spring to help disengage one wheel when making a turn. They tend to be noisy and can eat up tires over time.
The Bronco comes w/models, including w/Open Front and Rear, such as on the Basic model, a Locker Rear w/an Open Front, such as on the Black Diamond, and a Locker on both the Front and Rear, such as on the Badlands.
I don't know if Ford incorporates any traction control using the brakes.
Valhalla
Valhalla
Chattanooga Tn
Your Locker definition didn't cove mechanical lockers which "ratchet" and let the outside tire outrun the ring gear, but never let's one go slower than the ring gear. And lunchbox lockers which explode.
Then of course there are spools and mini spools... and the "Lincoln " locker where you weld your spider gears....
GoHack
Palmdale, CA
Yes I did:
Quote: "Then there are Lockers which are always engaged, which uses a spring to help disengage one wheel when making a turn. They tend to be noisy and can eat up tires over time."
If that's what you are talking about?
There's a wide assortment of different kinds out there.
As for the "Lincoln " locker where you weld your spider gears.... Those are just modified open differentials, used strictly for offroad. including dirt racing I believe.
Valhalla
Valhalla
Chattanooga Tn
I stand corrected.
Mr. jer bear
jerry
Fort Simpson NWT Canada
I offroad my motorcycle all the time and it's only 1WD. Why you need 4 wheels at all is beyond me.
Your motorcycle probably doesn't weigh 5000 pounds...lol my HD is 500. in the winter time I couldn't get out of my driveway with a rear locker.... living at my camp. Front locker would be nice either that or a winch, but a new bumper and winch is probably more than the locker.
