Line Out Converter Install?
Shec20
Kentucky
2022 Bronco
Just curious who all has installed a sub and amp using a line out converter? I just got a Kicker Kisloc2 and going to install tomorrow.
My question is should I use the kick panel speaker or the rear pods? The converter has a positive and negative for left and right; can I tie together both positive together and both negative together and connect to one speaker?
Trying to save a little money while learning. Thanks in advance!
Ford Bronco Line Out Converter Install? imag
‘21OBX
90Bronco19
2022 bronco outer banks
Def the front. The rears don’t have the output needed imo. There is a wiring breakdown for the plug from the head unit at the top of this category. I would hook up left and right but I’m far from a pro. I have a similar unit to what you have but I bought the plug and play kit.
TheMrTrend
Alex
Leavenworth, KS
'22 Ford Bronco
Where did you put your ground from the LOC?
