Light bar hookup using relay to the highbeam headlight
bparker4444
Bruce
Tennessee
2019 Jeep Wrangler
With past Jeeps, one of which I traded in for my new 2023 Outerbanks, I was able to use a relay switch from my high beams to trigger the light bar. This way, when my high beams were on, the light bar was on. When I needed to dim my headlights because of an approaching car, the light bar went off at the same time without me needing to hunt for the aux switch. Can I do that with my new Bronco? I read somewhere that the electronics are different on these. Anyone have a fix?
snowpup
2023 BRaptor
I wanted to do the same thing, but i was told that the hibeams are controlled by the canbus, not a discreet tigger wire that can be tapped, so no luck.
