Lifting clamshell off bronco
ven34
2024 Bronco
Hey guys, quick question. For those who have built or bought lifts for the clamshell, does the tailgate HAVE to be open when lifting the clamshell off the bronco? I haven’t been able to find a definitive answer.
thanks!
FleshTuxedo
A
PA
'22 OBX 2dr.
I would say yes because you have to have the back window up.
BitterBronco
Connecticut
2014 Tuxedo Black Ford Edge
I think @FleshTuxedo is right
But the more I think about it, I’m not sure there is a latch between the glass and the tailgate (and I’m not about to go look because that would spoil the fun)
Is there anything preventing the closed glass from lifting off the backswing gate? Could you open the back, unbolt the roof, close it back up, back up into the waaaaaay back of your garage, and then hoist the roof off with the glass and door closed?
timbal1963
Tim
Indiana
21 VB WT, 22&23 Bronco Raptor
thanks!
No. I have the lift from Lange and the tailgate and back windo do not have to be open if you are using that lift system.
Cysquatch
Adam
Rancho Cordova, CA
2016 CTS, 1996 Silverado 4X4
Hmmmm. I'm not sure about the glass/tailgate situation. The glass has to be closed first when closing the tailgate to form a seal. My guess is that if you hoisted it with both closed, the glass would hang up on the closed tailgate. Maybe back it up and the tailgate slightly open? I'll test it when I get home.
chill57
Clesson
AZ
Ford F150
I use a pulley lift sys and uneven lift would break the glass if it was closed. Sounds like hoist may be diff.
tdiddy
Tommy
Illinois
2010 Ford F150, 2012 Ford Focus
