Lift recommendation
DallasBBQ
Dallas
2022 Defender
I’m looking for a lift recommendation. Little background. I will use 4x4 extensively for ranch driving through fields and muddy roads but I will never go rock crawling. This is not a mall crawler but my off-road activity will not be extreme. I’m mainly concerned with on road drive quality. I really want a tight feeling rig that will be my daily drive. I would like to keep the lift/install under $1,500. Should I go cheap with a leveling kit or something more substantial if on road ride quality is my main objective? I plan to install 35 12.50 18 Nitto Ridge Grapplers. I do not have the Sasquatch package.
mike8675309
Minnesota
What are you starting with? Badlands, Base?
BlueBronco
DFW
Since you mentioned 18's I am guessing an OBX?
If your budget is $1500 I would skip the spacer lifts and look for some Squatch coil over take-offs. Those can be had for around $1k and will give you the clearance for 35's and the on road driving quality you are after.
mike8675309
Minnesota
Sasquatch coil overs also limit wheel travel at the rear. You would want to grab your bump stops off the Badlands to install in the Sasquatch rears.
swami37
Fort Lauderdale Florida
1950 Ford F-1 and 2020 F150 FX4
2 inch is all you need
