Less Squat on Non-Sas Badlands ?
Sitruc_btb
Curtis
Chandler, AZ
2022 Bronco Badlands
A budget boost and some bigger tires will help. A few brands have small spacer kits that work with the Badlands. I wouldnt go any higher than 1.5" spacers on the non Squatch Badlands shocks.
My BL on 1.5" spacers and 315's with 1.25" wheel spacers, to clear the upper control arms.
Ford Bronco Less Squat on Non-Sas Badlands ? 20231109_162959_HDR
EruptionBronco
New Jersey
2023 Bronco
For a base bronco do you recommend the same? Not sure If I have the same shocks and whatnot as a badlands. What do you think is the best looking lift height with 35's?
The base without Sasquatch comes with the black Hitachi shocks. Badlands comes with Bilstein, but the standard spring unless you add Sasquatch.
For 35s, I like 1 1/2 inches of lift. An affordable option that will improve brake dive and off road performance is the Bilstein 5100 shocks. A set of 4 can be found under $600 and they are adjustable from 1” to 3” of lift in half inch increments . If you search Bilstein 5100, you will find reviews from many Bronco6g members that are running them.
MNBigfoot
MN
The difference is lift between a Non-Sas Badlands and a Sas Bronco is only a half of an inch. A take-off set of Sas wheel/tires will get you almost there without a spacer lift, and realignment, a true set of 35's would get you within a quarter of an inch of the height you want.
Blu6GBronco
Blu6GBronco
4D Badlands
Crazy that the only difference between Sas and Non-Sas is a half inch higher lift, as to me the Sas has a more agreesive look / stance to me. Thank you for the info!
Jmanly
Joel
Phoenix
2018 Rubicon
I did the 1" leveling lift, modified crash bars and installed 35Ă—10.50 17 tires on the origional Badlands wheels.
Ford Bronco Less Squat on Non-Sas Badlands ? 20231118_135243
MNBigfoot
MN
Yeah, the Badland gets you .6" over stock and the SAS package is only 1.1". Not sure I'm willing to risk my warranty for a 1/2 inch.
Blu6GBronco
Blu6GBronco
4D Badlands
Yeah I suppose there's a risk vs reward decision I suppose... For a honestly surprisingly fractional diff. But looks soo nice. Arg. Decisions. Lol.
V1Rotate
Brevard, NC
2022 Wildtrak
Wheel offset and tire size on the stock sas will make it look different despite not being much higher
IwannaGOfast
Jon
Brea, CA
2021 4 door Badlands, 1991 Ranger Long Travel, 2014 Cruze Commuter
It also has a wider track width with the different offset wheels. And wider flares/bumper.
This is my standard badlands with Eibach replacement coil springs on 315/70/17's
Blu6GBronco
Blu6GBronco
4D Badlands
I like it. Realized this is a total noob question.... The offset is changed with diff width rims?
IwannaGOfast
Jon
Brea, CA
Not the width of the wheel, but where the wheel mounts within the wheel.
Ford Bronco Less Squat on Non-Sas Badlands ? wheel-offset
Blu6GBronco
Blu6GBronco
4D Badlands
Ahhh yes... That would make more sence... Thanks again guys. I realize a lot of these questions are obv for most. Always appreciated when I can ask questions on here and not get roasted. Appreciate ya'll!
BroncoAZ
Mitch
This is mine with 285/75R17 on +35mm offset wheels. Stock suspension but I plan on adding a 1” leveling block up front this winter.
Ford Bronco Less Squat on Non-Sas Badlands ? IMG_4366
Ford Bronco Less Squat on Non-Sas Badlands ? IMG_4066
Ford Bronco Less Squat on Non-Sas Badlands ? IMG_4061
Blu6GBronco
Blu6GBronco
4D Badlands
Looks nice. So you don't need the 1" in front level to run 35s? No rub?
