LeBronco Audio Build
LeBronco
'19 Expedition Platinum
description and more pics to come.
Ford Bronco LeBronco Audio Build 3EEA9FF1-16CF-47DA-BBBD-372DE916FC8E
Ford Bronco LeBronco Audio Build A1F1C7BD-353F-4213-873F-627C90DC4A6E
Ford Bronco LeBronco Audio Build 6FA931E9-8FED-448F-8F53-41825837C7E9
Ford Bronco LeBronco Audio Build 6742C7A8-140D-4087-BE02-74DE0929BC68
VoltageDrop
Fidalgo Island, WA
23, 69 Bronco
I would use caution leaving that much wire between the battery and the fuse holder. I had a similar fuse wire setup in my first Bronco and one day while bouncing around in the mud that wire rubbed a fender support bracket and shorted through the insulation. It sort of welded itself on there and burned up several things tying the body to the frame, including completely severing the parking brake cable going to the rear axle :oops:
LeBronco
It will be getting tech flex wrap but even without it is fine. It is not touching anything metallic. Everything it is touching is plastic.
chtucker
Kirkland, WA
FJ Cruiser
Ever wire a winch?
VoltageDrop
Fidalgo Island, WA
23, 69 Bronco
Ever wire a winch?
Most people don't run fuses on winches but that doesn't mean they shouldn't. You can certainly throw a 450A fuse right on the battery for one. I would at least put some split loom over that wire coming off the battery since there appears to be a bracket down there.
chtucker
Kirkland, WA
FJ Cruiser
Mega fuses are available in 450 & 500 amps which will work. Just need to find a good spot to mount it. That "should" run a 10k winch. I think the Warn 10K Zeon is quoted at max amps at 410, the 16.5TI is rated at over 500--Another option is this https://www.bluesea.com/products/7700/ML-RBS_Remote_Battery_Switch_with_Manual_Control_-_12V_DC_500A
But getting back to the OP.. Use crimp terminals, There is far less chance of voltage drop/corrosion/resistance or mechanical failure. Those screw terminals make it "easy" but it is not the best way to do things. If you are only using it a few times https://www.harborfreight.com/elect...mpers/hydraulic-wire-crimping-tool-66150.html
Tonka Bronka
Duncansville
F350, V60 Polestar, 900SS, K1300S, RnineT Racer
High dollar wire deserves full crimped connectors...
I knew that was coming, I like solder lugs and heat shrink myself. I must be getting old, I think the radio in my Bronco sounds alright.
edgeflyer
2013 FX4
I'm with you. More contact are than a crimp if done correctly and cleaner looking. You can also unsolder for modifications later if needed.
zombie
New Brunswick, Canada
Nobody who knows how to solder uses crimp terminals
chtucker
Kirkland, WA
FJ Cruiser
If you think crimp connectors are stronger than solder, you've never soldered anything properly.
I manage the tech in a fleet of over 3000 municipal vehicles.. Including a fleet of 15 boats from 15' to 90'+
