Lasfit Light Bar Install on Modular Bumper
Tank
Boone NC
18 F150, 18 4runner, couple of old Datsuns
I couldn’t bring myself to overpay for a simple light bar so Lasfit seem to be a decent choice so that’s what I went with.
I‘ve seen a couple of these light bars mounted on bumpers and wasn’t sold on the result. So I adapted the Lasfit 32” single row light bar to fit the modular bumper as close and tight as I could mount it.
This is completely out of the way of the camera on my badlands, I can still see the edge of the front bumper and it doesn’t touch the body trim below the grill.
Here is what I modified. The light bar came with 2 ways to mount, side mount and rear mount. The rear mounts can be used but you have to turn them backwards and that makes the light bar stick out in front of the bumper and does interfere with the camera. Wiring was a snap, I got the harness with the bar and cut off the switch that came with it and hooked the red wire up to AUX switch 3.
So I modified the side mounts. Basically cut the top off and mounted them utilizing the center most bolts on the modular bumper.
Ford Bronco Lasfit Light Bar Install on Modular Bumper 043CCD5A-8C03-4A54-B705-76B7EAA23492
Here you can see how they are oriented on the bumper.
Ford Bronco Lasfit Light Bar Install on Modular Bumper 8E62AA1A-9EC5-4922-B2C7-F5974E3D6F5F
The bronco bolt in the bumper are very close to the bottom of the light housing so I put a little piece of foam tape to make sure they didn’t rub. On the back side, I swapped out the hardware that came with the bar to utilize a hex head because I couldn’t tighten the Allen bolt that came with the bar. 10mm wrench fit back there with no problem.
It is very close to the trim but it does NOT touch.
Ford Bronco Lasfit Light Bar Install on Modular Bumper 706D838D-1B14-40BE-957D-590241BC3510
Ford Bronco Lasfit Light Bar Install on Modular Bumper A9D95210-BA12-4AE3-8F32-91693F442A77
Ford Bronco Lasfit Light Bar Install on Modular Bumper 5A707711-911C-4B15-80AA-B01F3DE631A9
Ford Bronco Lasfit Light Bar Install on Modular Bumper 51BF0F56-DFA6-4BF6-97EF-241D1A3E439E
Ford Bronco Lasfit Light Bar Install on Modular Bumper 3490B615-48BA-4078-A204-05634471F37C
Ford Bronco Lasfit Light Bar Install on Modular Bumper F2D69FE3-B79F-4968-8B34-BBE960D8E5DA
Ford Bronco Lasfit Light Bar Install on Modular Bumper F9E8FED7-2B8D-495A-90B1-76DCAFA46841
It’s not perfectly centered because of the space to put the nuts in the back rail are towards one side and it right where I would want it to be in order to be perfectly centered. Straight forward and simple, I think it turned out decent.
Also, an interesting nugget, while playing with this I noticed the bumper IS PREWIRED for fog lights. I didn’t know that prior to seeing the wires today on both sides.
Aman
Aman
Northern NJ
Looks great! Very nice work!
blackh8552
New Jersey
Obx Sasquatch 2.7 and explorer ST
Excellent , I installed the same light bar using the bottom mounts and was annoyed it blocked my camera a little. This is this weekends project now.
LowerDixie77
Alabama
1977 Bronco, 2009 F150, 2017 F150
Nice job Tank! Where’d you get or order the light bar from?
Corsair
Jacob
San Francisco
Escape
Too bad they didn’t do that for the ‘21s. :(
zedster
Las Vegas
'21 Bronco 2 dr Badlands SAS, '22 F150 PowerBoost
Aman
Aman
Northern NJ
If your modular bumper has front sensors, then it should have the foglight wiring.
Corsair
Jacob
San Francisco
Escape
Alright thanks. Haven’t had to get down there and check myself yet, but I could’ve swore that I read that it wasn’t wired. Thank you guys for clarifying.
zedster
Las Vegas
The wiring is supposed to be behind the tow points/hooks things ma jobs. I have heard remove the plastic covers around them.
Lifeliberty
Moonbeam👀
Columbus, OH
Question. Do these lights get hot? Hot enough to melt the grill trim?
Tank
Tank
Boone NC
Not hot enough to melt the plastic that is near it, especially while moving.
GroovyGeek
Boyan
'23 Bronco BD
Excellent, very elegant. Gotta take out the edge grinder and spray paint on the weekend.
A quick question - how did youmwire it? I have the aux switches and did not feeloke paying for a harness only for the connection point. Any tips on what I can expect to see when I cut off the connection and splice my own wire to it (with marine grade butt joints)
Tank
Tank
Boone NC
Thanks. I wired it to the front accessory wire that is in the upper core support. If I remember correctly, it is the purple wire. That makes is super easy, I ran the ground to a common ground.
