Larger Pillar lights
mdfilip
New Hampshire
20 Shelby GT350, 22 Bronco BL, 29 Ford Roadster
I know very little about what I should run so excuse my lack of knowledge on off road lights. I will be mostly using lights in snow and occasional off roading
I do not think I want a roof mounted light bar is there any reason not to put larger say 6" round lights on the pillar mount? I have only seen the 4" cubes in that spot. I will have the capable bumper with the factor LED Fogs and would like to add a couple bumper mounted amber lights and then just the pillar lights.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Go with the Baja Designs XL80 or the LP4. I run the XL80 on our demo truck. It's an AWESOME light with a lot of punch
https://www.4x4truckleds.com/baja-designs-a-pillar-kit-for-2021-ford-bronco/
Ford Bronco Larger Pillar lights 1647025429015
For snow you'd want an Amber Lens so you can order either 2x Amber (actually a yellow) covers OR get some Amber (actually yellow) lenses and swap them in:
XL Rock Guard: https://www.4x4truckleds.com/baja-designs-xl-rock-guard-amber/
XL Lenses: https://www.4x4truckleds.com/baja-designs-xl-series-amber-driving-combo-lens-kit/
PWillette
Parrie
Maine
So many options hitting the market place. What is your budget?
mdfilip
mdfilip
New Hampshire
Well I don't really have a budget .... I want good quality not cheap junk but I also don't want to pay more than my mortgage for lights :p
Lets say $1500 for 2 pillar lights and 2 front bumper mounted lights that I'm sure I will have to build some custom brackets for the capable bumper. I plan to keep the LED fogs that are stock but maybe later when available swap those for some amber fogs.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Check out the Baja Designs Kit I linked you. As for the capable... because they didn't give you any mounting points it'll be time before you see any (if anything exists) for it. That's why the Modular is so popular, lots more options to mount aftermarket accessories.
PWillette
Parrie
Maine
That's a pretty healthy budget and gives you a lot of choices...Baja Designs, Diode Dynamics, Heretic, Rigid and on and on. Try running a search, should be multiple threads discussing all shapes and sizes.
Cybindustries1904
Tony
Discovery bay
23 Raptor, Mach E GT
Im running 6.7 vision x light cannons
Ford Bronco Larger Pillar lights 20220304_163835
jalawson
TX
‘22 Bronco, ‘17 F150
Could you post a few more pics of this? I’m thinking about running the Rigid Adapt XPs on the pillars but I’m concerned they’ll be too big.
Cybindustries1904
Tony
Discovery bay
Jcr brackets 6.7 light cannons
Ford Bronco Larger Pillar lights 20220321_194454
Ford Bronco Larger Pillar lights 20220321_194445
4avor8ntfair
Houston, TX
BL-non SAS, 2.3 auto
I have the diode dynamics 6” amber fog lights in the bumper and they worked excellent in the snow a couple of weeks ago. I think they’re normally $350-380 or so. If you need lights for the snow and don’t have much of a budget, you might start with those.
