Lane centering on 2022 Bronco
PrepVet
North Central WI
A bunch.
Yeah this old system is pretty weak. I turned it off as I doesn’t do much than annoy you.
JerryC
Memphis
2022 Bronco
It seems that it will push harder if you are in a turn. Otherwise it doesn't do all that much when you are drifting out of your lane going straight. I've had some vehicles that would fight you changing lanes if you didn't have your signal on.
The lane centering our Bronco Sport was great, it's too bad they didn't put it on the Bronco.
Lanshark
Little Rock, AR
Infiniti
For me, lane assist is only useful on long interstate trips. It seems to reduce some fatigue. Not that I'm not mindful or wander all over the road, but its just enough to be helpful. In town or some shoulderless highways/roads, it really struggles if there arent VERY clear white or yellow lines. It doesn't do well recognizing concrete curbs. Also, if the road is damp and/or at night, the camera seems to struggle to delineate the lines and you have to lower your expectations to the point that you might as well turn it off. But, under ideal conditions it works great for me and I'm glad to have it.
Fmuguira
Frank
Idaho
Jeep TJ
Your “chip” went into someone else’s Nav ….. ! 😂
SCBronco1
Peter
2019 F150 Lariat Fx4, 2012 BMW X3, 2011 Escape
Try changing lanes without using a turn signal, if it fights you a little bit then its working.
