Knocking sound from bottom driver side door.
Arealhuman
James
Massachusetts
2021 bronco first edition
Hey friends, tried googling it didn't find much.
Seemingly randomly my bronco started making a knocking sound whenever going over uneven terrain fast or making a turn
The noise seems to be coming from the lower portion of the driver side door or below that or near the foot rest.
It's hard to tell, other than the noise I can feel a little thump you're my left foot while driving whenever I make one of these maneuvers
I can't seem to replicate it when I'm not moving by putting pressure on the driver side seat floor etc. I looked under The car didn't see anything loose. I'm not sure if it's coming from the lower portion of the door or inside the kick panel or what.
I know it's impossible to diagnose with just that information so I was wondering if maybe this had been a common problem at all.
For reference I have a first edition. I'm going to be taking the doors off in a few weeks and I guess depending on if the noise is still there that will eliminate the door being the issue
CKXVII
CK
F-150
I’ve noticed this in the past couple of weeks as well on my ‘21 (2.7L). Mine feels like it’s the DS footwell / floor board. Def interested if others have had a similar experience.
Arealhuman
James
Massachusetts
Ah it drives me crazy. I'll let you know if it's the doors. But it does feel like it could be under the floorboard as well.
Obviously mine is a 2.7 21 as well.
MayhemMike
Mercury
Take the door off and drive to see if the sound occurs.
Deleted User 5719102
Who's
On a Lake
22 2dr
Did you double check you front coil over top plate nuts in the shock tower? The three nuts may be loose and causing the knock sound while on uneven terrain.
Arealhuman
James
Massachusetts
Suspension was originally my thought but then it felt like it was coming from the door too much.
Is this something I could visually examine with the hood open or will I have to take the wheel well protector rubber out. Or can I look under the car?
In the attached diagram would it be part 7 nuts?
Ford Bronco Knocking sound from bottom driver side door. 665bc98a880e28192ef1c01ffcb1861
Who's
On a Lake
22 2dr
@Arealhuman
Yes you can take a wrench to all three without removing anything. At the top of the coil over there is a felt flap that is part of the wheel liner. You just lift up on that flap and all three nuts are visible and able to check for tightness.
Arealhuman
James
Massachusetts
@Arealhuman
Thanks. I'm away for the weekend but will check Monday
Zstngz
Stephen
Orlando
2012 Boss 302, Datsun Z, Merc E350
I have the same on passenger's side. 2 door base
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Hi James. Can you send us a DM with your VIN and dealership info? I can look into this for you.
Arealhuman
James
Massachusetts
Idk if you just took these, but thank you so much for going out of your way.
I've attached pictures. Mine looks nowhere near as clean. I guess Winters in the north have taken a toll. But it looks like the screw isn't an issue. I'll be taking the door off in the next week or two.
Ford Bronco Knocking sound from bottom driver side door. PXL_20230510_141712256
Ford Bronco Knocking sound from bottom driver side door. PXL_20230510_141707512
Ford Bronco Knocking sound from bottom driver side door. PXL_20230510_142201074
