Kicker 200.4 install issues
RdRdrFan
Peter
2023 Bronco
So I decided to take a bit this afternoon to install my Kicker 200.4 with the PlugNPlay harness. I may be missing something but I’m not getting any power to the amp.
Here’s what I did:
- unplug passenger side black harness from the ACM and plug into PnP harness. Plug other black portion of PnP harness into the ACM
- connect two harnesses from PnP with the long white connection.
- insert appropriate plugs from harness into 200.4.
My fuse is good. All connections seem to be seated firmly. No power to the amp.
What did I mess up?
I did unwind it to see if I had screwed something bigger up and it works fine. One of three things is wrong.
1 - I screwed up and missed something
2 - something is wrong with my PnP harnesses somewhere
3 - my amp is no good
I’m kinda hoping I get a smack up side the head and it’s an easy fix that I missed.
RagnarKon
Bryan
New England
Ford Bronco, Escape, Focus
Do you have a multimeter, and if so... are you getting 12 volts on the power pin of the PlugNPlug connector?
