Keyless Coded Entry
Beach_Bum
St. Augustine, FL
2023 Outerbanks Bronco
Thanks all! I do have both fobs.
Won't need the fobs. Just have the dealer reference the screenshot posted above. As indicated the master code can't be retrieved via a diagnostic scan tool. But there are steps that authorized individuals can follow to retrieve the existing master code.
Good luck.
DVO50
Darin
F350 Diesel, GMC 1500 3.0 Diesel
If the keypad was factory installed, there should be a sticker on the BCM that has the original factory code.
Kom2
Matthew
Tennessee
2023 Bronco
Where is the bcm?
DVO50
Darin
Behind the panel below the steering wheel.
Ducati1098
That doesn’t work for stick on keypads, only integrated ones.
DVO50
Darin
Not to argue with @Ducati1098 and his wealth of knowledge, but I went through a key pad issue when I picked up my '23. It had a non-remote start key pad installed from the factory and it was not capable of working with my Bronco (it was the new stick on type with the body colored cover), the techs were able to locate the code on the BCM sticker, but could not get it to function (other than lock the doors). The new, correct part works flawlessly.
Kom2
Matthew
Tennessee
2023 Bronco
It does have a body colored cover. Thinking I’ll go to another dealer tomorrow.
DVO50
Darin
If all fails, they can easily attach a new key pad and re-use the color matched cover.
JHawk
Ray
Heartland, USA
Fusion Sport
It sounds like you need the keypad and have it programed to the truck. The code digits are on a sticker behind the panel below the steering wheel (that goes for all Broncos). I think that there is a thread here with pics of the location. I'll post a link if I find it
Ducati1098
The SecuriCode card that comes with the BCM has nothing to do with the stick on keypad. It is not the correct code and will also not get you the correct code in any way.
Here is a thread that better describes what that is.
https://www.bronco6g.com/forum/threads/spare-key-card-in-cabin-fuse-box.76213/
JHawk
Ray
Heartland, USA
Fusion Sport
HotLap
Bradley
CA Central Coast
2023 Bronco, 2024 HD Street Glide & 2019 Yamaha XSR900
HotLap
Bradley
CA Central Coast
Yes, and there are YouTube vids of owners opening up the stick on pad to replace battery. Been a while since I came across it but it was there.
gwp
Greg
Winchester, Virginia
Harley Davidson FLTRUSE
At least with the Standard Broncos, none were shipped from the factory with them attached.
My 2022 was shipped from the factory with the keypad attached. I believe the standard you mention was adopted more recently.
