Keyless Coded Entry
Kom2
Matthew
Tennessee
2023 Bronco
Hey guys,
I bought my 2023 Raptor Bronco about 2 weeks ago and didn’t get the factory master code. Dealer told me today they can’t help me. They claim the device is aftermarket yet the window sticker shows the accessory. The dealer tried to scan it today.
Ford Bronco Keyless Coded Entry 73024819735__5D066FD8-E2A7-4A52-90E1-86FDDA43AAFB
Kom2
Matthew
Tennessee
2023 Bronco
The keypad is a dealer install, from a Ford part. Tell them you want to file a warranty claim.
Interesting. I could see 4 techs standing there with a scan tool. They gave up after about 30 mins.
MNBigfoot
MN
At least with the Standard Broncos, none were shipped from the factory with them attached.
Kom2
Matthew
Tennessee
2023 Bronco
Thanks for sharing! That’s awesome.
Beach_Bum
St. Augustine, FL
2023 Outerbanks Bronco
What were they trying to scan? Do you have the keypad on side of the door and the master keycode was not supplied? I presume you checked your glove compartment. As mentioned above, the keypad is a dealer install. You already paid for it.
Kom2
Matthew
Tennessee
2023 Bronco
Let me clarify. Certified pre-owned unit. Like 7k miles. No card where the original owner obviously kept it. I’ve got nothing.
it was my understanding they could get the master code from the OBD2 port?
Beach_Bum
St. Augustine, FL
Gotcha. Yeah, I don't think a code can be retrieved. Likely have to install another. @Ducati1098 Am I right?
I think what they will tell you is that you need to get a new keypad. They are "disposable" now with a battery, and just held on with VHB tape. If/when the battery dies - the procedure is just to replace it with a new one anyway, so it would get a new card / master code and would need to be re-programmed with FDRS.
When they were built into the doors there was a way to retrieve the code with FDRS I think. I don't know that they retained that with the new disposable design - but possibly (I don't know why they would necessarily remove it, but these things don't always make sense)
Also, check the fuse panel under the steering wheel. There is often a card tucked there. I don't think it will work with your keypad, but worth checking to see if they stuck the card for the keypad there as well.
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
One day we will stump @Ducati1098 with a question. :unsure:
One day, but today's not that day.
TrailRaider
Mr. G
So. Cal
Focus ST, Mitsubishi Montero, Bronco Badlands
If 4 techs at a Ford dealer can not figure out how to install a Ford accessory, find another dealer.
Instruction are easily found online on how to program a keyless pad. You should be able to do it yourself if you have both factory keyfobs.
Edit to add...
I found some info on other posts/places that Ford removed the ability to DIY install these for the 2019 and newer vehicles. It seems it now REQUIRES IDS or FRDS. If the dealer is going to charge shop rates to "figure it out", it's probably cheaper to just buy a new one and have them install that, Ford probably should have a pretty minimal install time for flat rate on it. The plastic cover that is painted to match the body can be swapped to the new one.
Apologies for inaccurate information. My opinion still stands about finding a different dealer though, that's pretty ridiculous.
Kom2
Matthew
Tennessee
2023 Bronco
Thanks all! I do have both fobs.
