Key FOB clear and Program with Forscan?
Douglasjwood
Doug
Wisconsin
Has anyone here used Forscan to wipe and reprogram keys for the Bronco? I got into the pickle of having too many keys, and need to get rid of some so I can program my spare. I've got Forscan extended license and have done the basic changes, like double honk, global window close, etc. I just want to make sure the key thing is reliable and someone else has done it before I attempt it!
Ducati1098
You can’t use forscan to program keys on the Bronco. Programming keys requires an FMC dealer login
Douglasjwood
Doug
Wisconsin
Well, that takes care of that one! Thanks Ducati for the info!
Valhalla
Valhalla
Chattanooga Tn
Will it allow you to program the key if you have the main key, seems like I vaguely remember doing this on a Lincoln once.
Ducati1098
Yes. If you already have 2 valid keys, you can program an additional key without needing any tools.
But.. there’s a maximum amount you can program and you still cannot ever clear the keys without a Ford dealership or locksmith that has access to the required credentials.
CalvinT
Calvin
Phoenix, AZ
There can't be more than four key fobs. If you've programmed four and lost one, the dealer will have to correct the problem, or maybe a locksmith.
Douglasjwood
Doug
Wisconsin
Had my Bronco shod the other day. While they were at it I had them program the two spare keys. Now I have a working fully functional spare for me and one for my wife. Reasonable price @ $70 for all four keys.
Neps
Floating off California
MX-5 30th, Focus EV, F150, Scout II (2)
That's a great deal, out here on the crazy coast the dealership charges $135 to $185 per key, dependent upon if you need it cut too.
