KC Lights on Capable Bumper
Lak34ers
Troy
Seattle
Following - Thanks guys, I was contemplating getting a whole new bumper (sill might??) but this gives me hope for the capable bumper and a bar !
In the same boat. I have diode elite's and don't really want to start over. Easier to put a bar on and add some light and maybe a light bar between the bumper and grille and just drill 2 holes to mount. Something like the rigid midnight would hide well.
ColeTrain84
Cole
Minnesota
'22 Bronco Badlands
Do you feel the guard provides a lot of protection or would a deer or animal just tear it off the top of the bumper and do a lot of damage. How sturdy is it when mounted? Any wiggle? Just wanting an opinion if it is worth it for protection or just not install it because it would not matter much. Thank you!
it is pretty solid and would provide the grille with a little added protection but not like a full blown brush guard or bigger bumper. I've already used it to push down some brush when running out to my trail cams for deer season. It worked good and has no damage :)
Eroc88
Ohio
Jeep
I really like the look this bar has on the capable bumper. Thanks for sharing 👍
MaddSkillzzz
Sacramento
1966 Morris Minor Traveller
Let me know if you wind up moving that hole backwards and cleaning up the front. That’s exactly what my plan is gonna be. Give a little more room to push it forward, and not have that little piece overhanging the bumper
Why not try throwing a washer under the bar in back to give a little clearance instead of welding, grinding and drilling? Might be worth a try.
Bertha
Peter
Charlotte
2023 Ford Bronco
I just received this nudge bar and love the option for the capable bumper. Obviously don’t want it to rub the paint but also don’t want the mounting bracket sticking out over the bumper. Considering adding some quarter inch steel spacers behind the bumper when mounting to bring it out just a hair. Has anyone tried this?
fiatlux
CA
Volvo V60 T8 Polestar Engineered
I was going for a sort-of retro look with the KC lights with stone guards. Pretty simple to attach the bar and wire the lights in to aux switches. Center spot to Aux 2 and outboard driving lights to Aux 1.
Which KC lights are those?
Vladandtanobronco
Vladimir
Houston
Toyota Tundra
h
looks awesome! i don't have the capable bumer....only the standard plastic one. Do you mind sharing the dimensions of the plate? i looked at the pictures and read that it is a 2" diameter pipe, but the plate looks about 3"X2.5"? The plastic standard bumper does not have very much room on it and wanted to see if you could measure and let me know? i called Rugged Ridge to get details and all they could share was the 2" diameter...and unfortunately they didn't have any other information,.
DJ1
DJ1
Minnesota
2022 Honda Civic Si, 2020 Toyota Tundra TRD Pro
h
I will measure when I get home. Won’t be for a few days.
CentralFLBronco
Jordan
'22 Bronco Big Bend
Anyone have any thoughts on this working for the standard bumper?
Mlarv
TN
I have the JCR winch plate on order. Will this have the clearance to go over the top of the winch? I really like that look, but with the capable bumper they are few and far between.
XPerties
New Jersey
2022 Badlands
The link to this shows me package deals. Is there a link that sells just the light bar?
Mlarv
TN
Here it is on the Rugged Ridged website. No matter which model Jeep you select it comes up with the same price and part number. Nudge Bar
CarbonSteel
Colorado Springs
2023 Carbonized Gray
@DJ1 + @ColeTrain84 - does the bar mounting plate end up flush with the front edge of the bumper or does it extend slightly past? How much gap is there from the back of the bar to the bottom edge of the grill?
Can either of you post a closeup of that area on both sides? Thanks in advance.
PS...what size button head bolts did you use to mount the bar to the bumper?
GI_Jo_Nathan
Jonathan
I thought it was interesting that this bar popped up being back in stock after so long of not being available. Still the same cheap price too.
https://a.co/d/2xXNGvp
Ford Bronco KC Lights on Capable Bumper Screenshot_20250207_145826_Amazon Shopping
