KC Fog Light Pocket Kit released.
Snapdragon
Diana
2023 Wildtrak 4-door
Thanks guys. There is no fuse on the front fog light circuit--I think the BCM provides current limiting. Seems though that the Flex Era fog mode may be drawing more current than the BCM will allow. I just ordered a set of fused relays on Amazon. I plan to install one of them to run the fogs and I'll replace the 30A relay fuse with a 15A fuse. 15A seems to be sufficient because fog mode works fine on my 15A aux switch. Don't want to fry anything though. I'll let you all know how it goes...
JonDW29
Jon
NoVA
'16 F-150
Definitely getting these for my Bronco. It's just a matter of when at this point.
Snapdragon
Diana
The relay fix worked great! Now I have the Flex Era SAE fog mode turned on and off by an OEM headlight switch assembly with the fog light pushbutton. This has a more OEM feel and saves me from using one of the upfitter aux switches.
For reference, here is a link to the relays I bought on Amazon:
https://www.amazon.com/dp/B07PK7F1MC?psc=1&ref=ppx_yo2ov_dt_b_product_details
waoudi
TN
Where is the OEM fog light button
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
duke90
Andrew
Orange County
2024 Wildtrak
I was considering these, but with the sae fogs only being rated at ip65 I would be hesitant to do any river crossings.
Chrgnthru
Palm Springs
2022 Bronco Wildtrak/BMW M5
Hey man.. Care to share how you went about getting this wired up with the fog switch? Just picked up this kit and would like to use that fog switch and save a up fitter switch.
Canyon Coolers
Canyon Coolers
Flagstaff
canyoncoolers.com
73 Bronco, Dodge 2500, Sprinter Van
I did this, without a rely. I ordered a new headlight switch from Ford (about $55) with the fog switch built in, and simply tapped the pre-existing fog wiring near the headlight. Works on auto, so I used the road legal wiring for the fog switch, and used an upfitter switch for the 'full blaze' offroad only light setting.
I found all the info I needed on various threads here.
