Kach Vartan
Kach Vartan
Los Angeles
Sedan
Got my @Fast Intentions Inc. exhaust installed. Went with the ceramic black coating to match the rest of the rig's theme. It looks and sounds great. A nice deep tone with a bit of rumble, but not obnoxious at all (in my opinion).
Big thank you to Kevin at FI for his knowledge sharing and to his team for the install. They were super quick and professional. Highly recommend them!
Ford Bronco Kach's Badlands Build IMG_4069
Ford Bronco Kach's Badlands Build IMG_4073
Ford Bronco Kach's Badlands Build IMG_4072
Ford Bronco Kach's Badlands Build IMG_4074
Ford Bronco Kach's Badlands Build IMG_4077
Ford Bronco Kach's Badlands Build IMG_4075
Ford Bronco Kach's Badlands Build IMG_4085
Fast Intentions
Simi Valley, CA
www.fastintentions.com
2021 Bronco 2.7L
Thanks for sharing your review and we appreciate your business. I'm glad to hear that you're enjoying the exhaust.
Your truck looked great in our shop the other day. Looks really menacing all blacked out.
Thanks!
Ford Bronco Kach's Badlands Build HM_1
Ford Bronco Kach's Badlands Build HM_2
Kach Vartan
Kach Vartan
Los Angeles
Sedan
Some recent updates:
1. Added the Tackform springload phone mount. I considered some the other options that involved a rail type mount and/or drilling holes into the dash. In the end, I convinced myself this was sufficient for my needs. It Is very sturdy and no issues when off-roading. I also added a small GoPro mount at the OEM mounting point. In the future I may consider Tackform’s grab handle iPad mount.
2. I installed the BroAddict door hangers and hung up my tube doors. The hangers seem pretty robust. I couldn’t keep a couple of the doors from swinging out (my fault as I didn’t install them exactly level), so I used a couple of hooks and some paracord to cinch them up against the wall. Hopefully in a couple of months will be able to swap the doors when the weather warms up.
Still sitting in the garage are the Ford Performance rear differential cover and my LOD skid plate. Those are slightly outside my comfort zone so probably taking to a mechanic for a professional install.
Future projects include a winch (I like the idea of the Maximus-3’s new removable winch plate), maybe a lift, and perhaps 37s when the Goodyears wear out (only 9k miles so far).
Thanks for looking.
Ford Bronco Kach's Badlands Build IMG_4678
Ford Bronco Kach's Badlands Build IMG_4677
Kach Vartan
Kach Vartan
Los Angeles
Sedan
Spent the past couple of days getting her ready for the official start of summer. First, a good wash to get rid of most of the mud and sand from the last couple of trips.
Then, on to removing the hardtop and swapping in the soft top. I’m calling this project an 85% success. For some reason, we could not get one of the soft top bolts to line up on the left side. Probably means I need to adjust the receiving brackets a bit more, but after a couple of hours of fighting with it (and a few deep scratches on the roll bar), I gave up. Hoping the two bolts on the left side will be secure enough for now. Oddly, the soft top seems to work fine - opens, closes and latches relatively easily (even with my JTops hard top version in the way).
Any recommendations on a good paint touch up kit? Dr. Colorchip seems to get good reviews.
Ford Bronco Kach's Badlands Build IMG_5724
Ford Bronco Kach's Badlands Build IMG_5723
Kach Vartan
Kach Vartan
Los Angeles
Sedan
This weekend’s project. Step one complete. Now if I can just muster up the coverage to install this myself….
Ford Bronco Kach's Badlands Build IMG_5736
Kach Vartan
Kach Vartan
Los Angeles
Sedan
Added the extension for the spare tire bumper. Kudos to the forum member who suggested using the standard dishwasher drain hose. Picked it up from Home Depot for $8 and cut it to size. For my 0 offset wheels, that was approximately 7/8” past the end of the existing Sasquatch stops.
Ford Bronco Kach's Badlands Build IMG_5739
Ford Bronco Kach's Badlands Build IMG_5740
Kach Vartan
Kach Vartan
Los Angeles
Sedan
Wrapped up the install of the Warn Zeon winch and Maximus 3 winch mount. Probably took 5-6 hours all in over a couple of days working alone, including adding quick connects to the winch and adding the frame home reinforcements from the FP winch kit. Still have a few minor adjustments to make as the tolerances for the Maximus mount are pretty tight, but looks good and everything works great.
If I have the energy, will try to add the Raptor tailgate hinges tomorrow…
Ford Bronco Kach's Badlands Build IMG_6128
Ford Bronco Kach's Badlands Build IMG_6124
Ford Bronco Kach's Badlands Build IMG_6113
Ford Bronco Kach's Badlands Build IMG_6133
Ford Bronco Kach's Badlands Build IMG_6127
Ford Bronco Kach's Badlands Build IMG_6131
Ford Bronco Kach's Badlands Build IMG_6134
Ford Bronco Kach's Badlands Build IMG_6130
Ford Bronco Kach's Badlands Build IMG_6132
RWizzy
Ross
Cumberland, BC
2021 Bronco Wildtrak
Hey did you find the added weight of the winch made the front sag? I've seen a few threads saying they did. I have a bumper and winch on order so trying to work out if I need to level the truck when I get one.
Bronco looks great!
Kach Vartan
Kach Vartan
Los Angeles
Sedan
How’s the XPEL holding up?
It’s held up really well. I’ve been on a few tight trails where I was scraping dry brush and no long term pinstripes, so the self healing must be working. I do have one corner of the film on the rear passenger door that has peeled very slightly. I think more the installer’s fault than anything else. I may just super glue it down so it doesn’t become a problem later.
Kach Vartan
Kach Vartan
Los Angeles
Sedan
Bronco looks great!
It definitely causes a visible sag, maybe 3/4 of an inch. I think any larger winch would do that unless you had heavy duty springs up front. Doesn’t bother me too much though as this is not a permanent mount.
