Status
Not open for further replies.
JcrOffroad
JcrOffroad
Portage, Mi
2021 Ford Bronco Badlands
@JcrOffroad if you wanted to add a wooden table that slid out to the right, would this be possible? Similar to how Goose Gears table works? Table extension
Would love to have this ability for the times you need extra space or a cutting board. If the right side is open between the table and MOLLE it would be an easy add.
We are a metal manufacturer, so we are just going to stay in our lane. If that is what you are after, goose gear has you covered.
JcrOffroad
JcrOffroad
Portage, Mi
You are referring to the Ford table correct? Do we know if this JCR table works with the enclosure? I have the enclosure, and will order this table in a heartbeat if it works with it.
We have no idea. Only have seen pictures of the enclosure, no direct experience.
JcrOffroad
JcrOffroad
Portage, Mi
very nice solution, going on my list of things to maybe buy, the no drill is definitely a plus, I'm not a fan of drilling holes in my cars.
I am concerned with the rubber latches though, in my experience rubber+time+heat=failure eventually. Are these made of a rubber that will withstand heat and sun and ice and snow? And/or easy to replace via Amazon or hardware store, or something custom only you will carry (for a while)?
I'd generally prefer metal latches (with springs if extra tension is needed to prevent rattle).
But so far one of the nicest solutions I've seen, I won't need one until at least spring, so bookmarking for now and keep on designing great stuff for us!
We use these rubber latches on our tire carrier tables. Have had no issues with failures. Their designed application is to hold semi trucks battery enclosures closed, so I’m confident saying they are robust.
nottinbe
St. Louis, MO
If you need me to be a guinea pig I can send you my address : )
Cable Guy
Kurt
Audi RS7
Sweet catch. How’d the fish taste for dinner? Does it come with some PBR by chance?
Tdecell
Trey
Clinton, MS
2004 F150, 2021 Outer Banks, 2022 Badlands
Sorry, just saw this...Yes, I'm referring to the Ford table.
slypops
Reggie
N/W Florida
79 Ford F-150 4x4 , 11 JK wrangler
Since the first batch is made, I'll order now! (says the man with a 2021 Bronco!) Will order the bully bar when someone verifies it won't block any of the 20 cameras this Badlands has. Hopefully my table will arrive as the install video goes live. Thank you!
Bird Dog Off Road
Jody
Dallas, TX
www.youtube.com
Happy New Years! First batch of tables are on their way!
Just placed my order, what is the ETA of the Second batch (assuming I even made that, LOL)?
mbagne
Placentia, CA
Mach-E GT
I don't know, seems like an innovative idea on its face to combine a molle panel with a table, but think about it . . . if the molle panel is loaded with a bunch of gear, pouches and whatever, you probably wouldn't want to fold the table down, or you would have to take stuff off the molle to use the table, which would translate to just not using the table. This would probably be the case with me. Again, seems cool on the surface but not that practical in use.
amccue90
Andrew
Illinois
2021 Badlands
What in the world?
Why would you need to take the stuff off?
Unless you have an open molle pouch full of nails with no drawstring enclosure, you just leave everything on. It would end up on the underside of your work surface when you open it.
I'm just trying to figure out if I had too much to drink or if you did.
mbagne
Placentia, CA
Mach-E GT
What in the world?
Ha, well I get your point, if you hang molle items in neat, tight little pouches . . . but some of us use molle arrangements in ways that would not hang well when inverted downward. Note too that if you already have a lot of weight using the molle portion it would limit how much weight can be placed on the table when folded down. Just saying that a design like this is not optimal for all users, it can be problematic. Sounds good for you and that's fine.
Status
