Status
Not open for further replies.
amccue90
Andrew
Illinois
2021 Badlands
Ha, well I get your point, if you hang molle items in neat, tight little pouches . . . but some of us use molle arrangements in ways that would not hang well when inverted downward. Note too that if you already have a lot of weight using the molle portion it would limit how much weight can be placed on the table when folded down. Just saying that a design like this is not optimal for all users, it can be problematic. Sounds good for you and that's fine.
What you hanging on there? A BAR and a couple hundred rounds. Any MOLLE will jostle around unless tight.
Sincere question
Gtrekker
Gary
NJ
mbagne
Matt
Placentia, CA
Mach-E GT
Sincere question
Exactly . . . and that is my point, not everyone arranges their molle "tight" with items. I take it that you probably hang items on a molle in tight little pouches and small gear "strapped in" just right . . . they way a molle SHOULD be used. But let's agree that many of us are not that smart, and get lazy using the molle as a helpful source for storing (read "hanging") random gear, even at a whim to just hang something temporarily while camping. Many of us use a molle that way.
Ford Bronco JcrOffroad Fold down molle table has been released! Molle
Losy
Long Beach, CA
Gen 1 Raptor, GL63, S7
i guess i was expexting more. Better aftermarket option already out there.
SuicidalSmurf
Washington State
22 Velocity Blue Base Diamond
You are referring to the Ford table correct? Do we know if this JCR table works with the enclosure? I have the enclosure, and will order this table in a heartbeat if it works with it.
We have no idea. Only have seen pictures of the enclosure, no direct experience.
I hope you can figure out/confirm compatibility. I suspect a lot of people are going with that enclosure since hard tops are so hard to come by right now. Definitely like a no drill solution but will forego a table before I forego a secure enclosure.
GrumpyVet
Joel
Word of advice. If you find yourself laying in bed on your phone with the wife sleeping next to u at 03:45 and you come across a rap siren, don’t click the button. 😂
amccue90
Andrew
Illinois
2021 Badlands
Which option is that? And why is it better?
amccue90
Andrew
Illinois
2021 Badlands
Losy
Long Beach, CA
Rockslide engineering. Shelf & table.
Goose Gear as well as outback adventure incorporates a wooden cutting boat and extends the table.
but this one look nice as well. Not trying to be negative, I just like the cutting board on some models. Let us know how the install goes. Enjoy.
amccue90
Andrew
Illinois
2021 Badlands
No negativity read. I just like to know all options. A no drill install allows for a clean upgrade if something I like better comes along
Tdifonzo
Thomas
Audi S3
Installation video being shot today!
Any ETA on when this will be up? I received mine today and am stuck fitting the tabletop into the MOLLE panel. It's almost as if the tabletop isn't long enough to reach both sides. I'm hoping the video can show me I'm stupid. Lol
GloNDark
Reno NV
1973 Bronco Ranger & 2021 Bronco First Edition
Thank goodness it's not just me. I got mine today. Started assembly and got annoyed put the table slots into the back panel.
Let's see the video haha. Over all it's a great piece. VERY well packaged. Wow. I've not seen anything this well packaged in a long time.
JcrOffroad
JcrOffroad
Portage, Mi
2021 Ford Bronco Badlands
Looks like we may have a small batch issue with the main molle part of the table being bent incorrectly. I’ve had a couple confirmed installs without issue, and a couple with issues.
if you are having this issue, please reach out to our customer service.
We’ll send a replacement panel. In the meantime, if you want it installed, you can shim the table part down, using washers between the two panels where they bolt together.
[email protected]
269.353.1184
Blitzjb
Joel
Long Island
2021 Ford Bronco OBX
We had a tech in our shop drill right through the tailgate of one of our mannequin broncos installing the Ford table. NO DRILL FTW!!
I guess I’m smarter than your tech. I didn’t drill thru mine when I installed it
Status
