What is wrong with cables?Has anyone brought out a table option that doesn't rely on the side cable supports?
Thanks for the info - cancelled my table order until something better comes alongI just got my Bronco last Saturday, I installed both the table and the lidded rear storage compartment. There is a rubber seal on the edge of the lid that seals against the tailgate when closed. The latches on the table hit right at the lower edge of the seal, so that when the tailgate is opened, the flat top of the latch handle hangs up on the seal and has already torn the seal at both spots it touches. I would have thought the engineers should have seen this beforehand and changed the design of one or the other accessories to work together.
Love the looks of that one.If you guys missed it, we released our drop down molle table for the bronco!
1.) Doesn’t rattle!
2.) Flat table when folded down.
3.) No drill installation!
4.) Made In the US.
The first run of these will be shipping the first of the year! So make sure yiu
https://www.jcroffroad.com/product/BR6-TAB.html
I just don't like the way the sides of the table are confined by them. Like if you set a propane stove on it, it would have to sit squarely within the side to side dimensions of the table surface as the cables are creating sort of an artificial side wall. I'm sure they are perfectly fine, probably better, structurally speaking.What is wrong with cables?
You are referring to the Ford table correct? Do we know if this JCR table works with the enclosure? I have the enclosure, and will order this table in a heartbeat if it works with it.I just got my Bronco last Saturday, I installed both the table and the lidded rear storage compartment. There is a rubber seal on the edge of the lid that seals against the tailgate when closed. The latches on the table hit right at the lower edge of the seal, so that when the tailgate is opened, the flat top of the latch handle hangs up on the seal and has already torn the seal at both spots it touches. I would have thought the engineers should have seen this beforehand and changed the design of one or the other accessories to work together.
