Jacking under hitch?
BlueBronco
DFW
While not ideal, yes you can use the hitch as a jacking point if necessary.
Tongue weight is the max amount of trailer load to be distributed to the vehicle, not how much physical weight the hitch can support.
Fordified1
Bob
Mid South Texas
OK, as a safety measure, I can see it, And yeah, a DP rear Sub Frame is beefy on an XC Chassis (assuming it's an XC anyway, I'm not very familiar with the other DP Chassis's)...
We’re off subject but as a safety issue it needs to be said that gas class A’s and many Class C motorhomes do not have full-length full-size frame-rails all the way to the hitch and most should never be used for jacking it up or supporting it’s weight.
Also remember leverage comes into play when jacking on a hitch. Closer to the frame is always better.
Bronkers
Bronkers
Ben
Las Vegas, NV
2022 2dr Bronco
