Is this the correct brackets for Rock Rail?
Shoeman
Brandon
San Francisco
Toyota
I received a set of Ford Rock Rails for my friend for my new bass bronco four-door. However it didn’t come with brackets.
Is this the right brackets to purchase?
Ford Bronco Is this the correct brackets for Rock Rail? IMG_0730
Ford Bronco Is this the correct brackets for Rock Rail? IMG_0699
BlueOvalBandit
Kenneth
Anaheim, CA
Tacoma
Well they don't look like the brackets when I pulled my rock rail. That doesn't mean they won't work.... Just they're not the same as factory. I'd be a little leary paying $150 for something that may not work. If I have time/remember later I'll snap some photos since mine is still sitting in the garage
Herbie
Alex
Cleveland OH
2022 Badlands
No sir. You need to find the OEM brackets from Ford. Those are from an aftermarket company. Like @BlueOvalBandit they might work, but I wouldn't skimp.
Shoeman
Shoeman
Brandon
San Francisco
Toyota
I called Ford and they told me that they don't sell only the brackets. So, I started looking for a set of aftermarket parts. Is this bad information?
Shoeman
Shoeman
Brandon
San Francisco
Toyota
Thank you! Ford told me they don't sell just the brackets.
BlueOvalBandit
Kenneth
Anaheim, CA
Tacoma
kodiakisland
Arkansas
Hope you got a deal on the rails as they knew you’d need the brackets too.
Here’s what they look like on the 2 door.
Ford Bronco Is this the correct brackets for Rock Rail? IMG_2922
Shoeman
Shoeman
Brandon
San Francisco
Toyota
MFP2241
WV
2 Door Antimatter Blue BaseSquatch
Yes, you can buy just the brackets from Ford. The OEM rock rails I bought didn't come with brackets either, they are around $38 each.
OEM bracket part numbers are M2DZ-54200B38-A and M2DZ-54200B39-A, you need 2 of each.
Shoeman
Shoeman
Brandon
San Francisco
Toyota
Yes, you can buy just the brackets from Ford. The OEM rock rails I bought didn't come with brackets eiter, they are around $38 each.
Thank you!!!!!
Shoeman
Shoeman
Brandon
San Francisco
Toyota
You are the best!!!! Thank you!!!!
swooshdave
Portland, Oregon
Mustang
I've seen rock rails from everywhere from free to $600. If you can find some cheap enough with the brackets it might be cheaper than getting from Ford. Also why would someone get rid of the rails without the brackets?
Shoeman
Shoeman
Brandon
San Francisco
Toyota
I got them for Free since the person used the brackets to install steps that didn't come with brackets.
swooshdave
Portland, Oregon
Mustang
I guess maybe the steps use the same brackets? Interesting.
