Is something wrong with my transmission?
Roger123
Roger
VA Beach, VA
MNBigfoot
MN
Globally sourced mass manufacturing is going to be a difficult pill to swallow.
Definitely don't look up where most of the content in your Bronco comes from.
Going with the ricer tranny, the least they could have done is made it a 3 speed on the column for the enthusiasts.
jbacchi70
jbacchi70
Jeep GC, 1968 Plymouth Road Runner
Is there an advantage going with that option over the Forscan delete?
From what I understand, the forscan delete will give you an error message every time you start the vehicle. Not something I would want, but some people are ok with that.
illverado
Cory
700whp stick shift 2000 silverado 23 basesquatch 2dr 7mt
Yes, the 10 speeds have many common issues and when you take it in it will get taken apart and sit there next to the other ones while basic parts are on backorder. Someone I may or may not know works at a place that sells certain vehicles and they’ve worked on every single 10 speed transmission vehicle they have sold. There’s no updated parts either it’s just the same stuff over again. Make a big deal out of it call ford etc and learn to drive a manual transmission if you plan on keeping a bronco or any brand new vehicle for a while
Ducati1098
Sounds like the slip yoke might be binding and needing to be lubed. This was common issue on F150's. Do a search for "f150 drive shaft clunk" on google.
The bronco doesn’t have a slip yoke.
Ducati1098
i deleted mine with forscan, no error messages, works great.
Ducati1098
Transmissions with internal damage don’t get taken apart under 3/36. They just get replaced with a new one.
Ducati1098
Bring it into the dealer and tell them you have harsh shifts. There is a SSM (50529) for a repair that they can do.
jbacchi70
jbacchi70
jbacchi70
jbacchi70
It only happens when I do a sudden stop. I fully believe it’s the issue with the drive shaft as mentioned earlier.
mike8675309
Minnesota
Automatic transmissions don't generally have something that "clunks" inside it. Things attached to it can go clunk, but the transmission shouldn't generally do that. If you can duplicate the behavior, make an appointment with the dealer and describe specifically how to duplicate it. If necessary take a drive with a mechanic to point it out to them.
jbacchi70
jbacchi70
Oh it’s definitely repeatable. I am convinced it’s the drive shaft.
