Is it possible to borrow a tuner from someone?
mdepalma
Salt Lake City, Utah
Hey I want to upgrade my 2.7L V6 with the Ford Performance tuner, but it is almost $700. Is it possible to borrow the tuner from someone so I don't have to spend $700 for something that is a one-time use?
userdude
Jared
Denton, TX
2023 2dr Badsquatch
You can if they give the Bronco too. Otherwise, no. It's good for one Bronco only, and don't screw it up.
Ford ProCal is VIN locked to the vehicle it is first installed on.
So you can borrow the box, but it won't do anything for you.
mdepalma
mdepalma
It isn't a one time use, it gives you the tune... Which you use every time you drive it.
It stays plugged into your car? I thought you just need to download the file to your vehicle and then you're done. I'll do more research
MichiganMichael
'21 F150 Lariat FX4 Sport, '22 Explorer XLT
No, they are just saying you use the tune every time you drive, as it's loaded into the vehicle. But also, the tuner stores the stock tune so you can flash back to stock if needed.
If you could pass around tuners and use them repeatedly, then no one would ever buy the tuner, everyone would just pass them down to the next guy.
GoHawks63
George
Metro Detroit
2024 Bronco Wildtrak, Cadillac CTS-V Coupe, Roush Stage 3 Mustang convertible
Almost all tuners upload the tune to the car and don't need to stay connected.
The issue is that the tuner is "married" to a VIN. It's essentially locked to that car and won't upload the tune to another vehicle unless it gets unlocked, which then won't work for the person you borrowed it from.
mdepalma
mdepalma
If I'm not mistaken it sounds like you still have to use it once and then never bother with it again
GoHawks63
George
Metro Detroit
Correct, unless you want to revert back to the factory tune.
