Introducing the Diode Dynamics SS5! (The World's Brightest OFF-ROAD LED Pod)
Lagrange 6g
Tony
Austin , tx
2018 f250 2014 landcruiser 1978 cj5
Dom
Dom
Phoenix AZ
2000 Ford Expedition, 2013 Ford Fusion
Question......If you choose the amber lense, how does that affect the back light coloring? These hit a lot of my wants for for pod lihgts. Very nice design.
chris@pandamotorworks
St. Louis
2016 F250, 2013 Ford Focus ST
Would only get Amber Backlight
now you can do clear and we can include free Amber Covers!
  • Like
Reactions: Dom
St. Louis
Dom
Dom
Phoenix AZ
Ok, so I buy the clear version with the 8 different backlites in the Pro light level and free yellow covers? Hmmmmm, man, you are making this hard. Were you a drug dealer in a different life? Ever sell ice to an eskimo? LOL
St. Louis
That is correct.
15% OFF & FREE YELLOW COVERS PROVIDED BY US FOR YOU!
Let me know happy to get that invoice over to you!
  • Like
Reactions: Dom
Dom
Dom
Phoenix AZ
Sadly, due to the upcoming holidays a purchase liket his is hard for me, but I still may take advantage of the discount and pull the trigger. Regardless, these are now on the top of my list for A-pillar lights. Thank you.
St. Louis
I will go ahead and shoot you a PM!
  • Love
Reactions: Dom
Dom
Dom
Phoenix AZ
Apparently Chris is some kind of voodoo warlock wizard. He got me to pull the trigger on these pods. Thanks again for reaching out. You are the 2nd vendor to get someof my money. LOL. I will osmeday have a Bronco to put these on. Have a happy thanksgiving weekend!!
Bob Blaylock
Bob
38°29′ North 121°26′ West
2016 Dodge Dart
*Pro Tip* If running with the Windshield Lightbar Kit, we recommend using Aux Switch 2 (if applicable) because it uses the same gauge wiring as switch 1. If your power requirements exceed 15A, we recommend upgrading to a 20A fuse.
As an electrician, I have to suggest some caution, here.
Although the wire used on switch 2 ought to be heavy enough to handle up to 30 amp, I have to think there is a reason that Ford only put a 15-amp fuse in the location. I would caution against putting any higher-rated fuse there, without first making some effort to verify that there is not some weaker part of the circuit that is only rated for 15 amps.
Probably wisest, if you want to use that switch to control a circuit with more than 15 amps, to use a relay that is rated to handle whatever load you are going to put on it, and use the circuit from the switch to control that relay.
St. Louis
Ford changed the Amp rating last minute. Originally it was 15amp max circuit if I recall.
Mitch does have a slight typo here we recommend upgrading to a 20amp not 30 for the bumper bar.
St. Louis
I'd love to see a shot of the front camera image with these installed. Thanks!!
I do not have a front camera on the current bronco but it is very similar cut off as the Baja kit. Minimal interference
wanna1
Andrew
2013 Ford F150 Platinum 4x4 2022 Mach E
BTW - Happy Thanksgiving & don't answer this until Friday.
I went to your site but didn't see a picture of the camera image of the Baja kit. Do you have one posted elsewhere?
Thanks!
St. Louis
Thanks!
You too man!
This is from another forum member!
Ford Bronco Introducing the Diode Dynamics SS5! (The World's Brightest OFF-ROAD LED Pod) Screenshot_20211125-120646_Chrome
Thank you
