Interior Tail Gate Trim Panel Replacement (broken plastic clip)
SPITmadFIRE
CA
Howdy! Hoping someone knows where I can find a replacement plastic vent for the tailgate, pictured below. After pulling mine off, I found the part number M2DB-S41314-AD319W on the back of it, but I’m unable to find anywhere online that lists the part. Even the parts diagrams I could find don’t include this trim piece (or the other tailgate vent trim piece).
Any leads on getting a replacement for one of these would be super appreciated!
Ford Bronco Interior Tail Gate Trim Panel Replacement (broken plastic clip) 1665359853895
joeb
Pennsylvania
FJ Cruiser
Hi,
Looking for same panel.
Any luck ?
Thanks
SPITmadFIRE
SPITmadFIRE
CA
Hi,
Any luck ?
Thanks
Nope, no luck. The part number doesn't help searching much which is strange. I've had tons of success using those part/engineering numbers for searches on Tasca or other parts sites before, but I can't find this one anywhere.
Sorry to be a pest to @flip by tagging you here, but I've seen a bunch of other parts diagrams floating around on the forums. Wondering if you have any info that might help here?
joeb
Pennsylvania
FJ Cruiser
Thanks for reply.
I'll keep looking and if I find it, I'll let you know.
joeb
Pennsylvania
FJ Cruiser
Ok, I think I found it!
Going to order one and see.
It's about 25-30$.
If it's the one, I'll post all info.
Went for fed ex 2 day , was only $9.99
Not sure where it ships from.
Don't want to get your hopes up if it's not right piece
SPITmadFIRE
SPITmadFIRE
CA
feel free to post the link, appreciate you saying you’re not sure if it’s the right part first
Lifeliberty
Moonbeam👀
Columbus, OH
I looked through all the part diagrams i could find. I didn't this piece on any i looked at. The service manual refers to it as flipgate trim(or something close to that) , but no luck with that either.
SPITmadFIRE
SPITmadFIRE
CA
who knew webasto was having trouble making these trim panels too 🥲
joeb
Pennsylvania
FJ Cruiser
Here I believe is the correct part # based on what comes up when you put in your Cart
And also the diagram. It's on FordParts.com I think. Let me make sure
Ford Bronco Interior Tail Gate Trim Panel Replacement (broken plastic clip) Screenshot_20221016_173208_Gallery
Ford Bronco Interior Tail Gate Trim Panel Replacement (broken plastic clip) 20221016_154819
Ford Bronco Interior Tail Gate Trim Panel Replacement (broken plastic clip) Screenshot_20221016_020612_Chrom
UncleBuck
Washington
2011 Ranger XLT 4.0L - 4x4
Did you break the little plastic tab on the top right on the back of it? The tab that's different from all the other tabs on it? Yeah I did too. I just stuck a piece of sticky foam behind it where that tab was and it doesn't move or rattle. I'm the only one that knows it's broken.
joeb
Pennsylvania
FJ Cruiser
Yes, Same clip.
UncleBuck
Washington
Yes, Same clip.
Yeah I'm not sure what they were thinking with that tab. Again, I stuck a piece of sticky foam there and said "F" it. Works fine for me.
joeb
Pennsylvania
FJ Cruiser
Yeah, I thought about doing that. Probably will. And keep new one for when if I break more things on that panel.
