Interior Lights not working at all
Carbon6G
2022 Bronco, Carbonized Grey
Hi all,
Dome lights and cargo area light do not light up. Neither by manually hitting the button or by opening the doors. The button that is supposed to control the the lights going on and off when the door opens is also not illuminated (not sure if it's supposed to be or not).
Any ideas?
Thanks!
Copperhorse73
Justin
Mooresville, NC
If I remember correctly there is a brightness setting in your vehicle settings menu. This happened to me and it was turned all the way down
Carbon6G
Carbon6G
I was not able to find such a setting in the menu, manual, or online. Only a setting for ambient lighting.
Carbon6G
Carbon6G
Thanks, but I can't find a fuse to check in the manual or online. and have read here that the BCM controls interior lighting which has 5 fuses, none of which directly correlate to the dome light, etc.
Hopefully, someone has some insight.
JohnnyBronco
Pennsylania
X4
The dome light switch in the overhead console above or in the mirror should itself be lit. And it is shipped in the off position. Took me a year to figure out I could have interior lights . But if your switch is not back-lit then you may have a wiring harness issue.
Is this something that just happened? After fjording feet of water and?/or mud rocks branches or have you never had interior lights of any kind?
Carbon6G
Carbon6G
I have about 600 miles on the vehicle, haven't touched any wiring or gone offroading, and everything else seems to work just fine. I'm pretty sure the dome lights never worked, it just took me a couple hundred miles before I noticed. I'll take a pic in a few of the buttons near the dome light area, and maybe you can confirm if it looks like something is not working correctly. Appreciate it.
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Hi all,
Any ideas?
Thanks!
Good morning! Can you please send over a message with your VIN and the name/location of your local Ford dealer? I would like to look into this light issue on my end.
Carbon6G
Carbon6G
Here is what I see, 3 illuminated buttons that do nothing when i hit them, and one dark button to control lights when door opens (which also seemingly does nothing for me).
Ford Bronco Interior Lights not working at all IMG_5477
Carbon6G
Carbon6G
Can anyone assist or confirm that its back to the dealership for me?
2nd time in 400 miles… Fans failed the first time at 65 miles.
the314boss
St. Louis
2023 Bronco Raptor
for anyone else looking for an answer to this question, it is the button on the right side, closest to the "passenger airbag on" indicator light.
as another poster commented, it is set to "off" from the factory (which means it will be lit). i was perplexed about this myself for the first two weeks of ownership...
Carbon6G
Carbon6G
Sorry but no… I wish it was that simple.
For anyone experiencing the same issue I had here, there was a short in one of the sensors that tells the system the doors are open or closed. They replaced the entire control module first, that wasn’t it. They found the short and replaced the trunk door sensor. Good to go now 😎
betzgb
Greg
Dallas, TX
I am having a slightly different issue. If I press the individual map lights they turn on. However when I open the door the lights do not come on. They used to come on but at some point stopped working with the door ajar. The button near the right side, closest to the "passenger airbag on" indicator light makes no difference whether pressed and glowing orange or not pressed (dark). Any guesses on what it could be? I am still under warranty but avoiding my dealer because they keep it for 2-3 weeks each time without a loaner available.
orion
Jeremy
17' F-250, 17' Explorer
Have you messed with Forscan? There's a Dark Mode that may have accidentally been enabled??? Just a thought...
betzgb
Greg
Dallas, TX
Ok, feel kinda silly but the issue was my battery was weak so the car was shutting down all systems when the ignition was off including the dome lights. I figured it out because when the car was running and you open or close the door the dome light behaved as expected. When the ignition was off, total darkness when opening the door. New battery and everything is working as normal again. Just thought I would post the outcome incase others run into the same.
